understanding ports, a lesson in dimensions vs efficiency.
excellent read guys!!
Thank you much for taking the time to write all of the information in this post!!
seen as i do have some port alterations to my existing box, i am really starting to wonder if i wouldnt just be better off to start all over from scratch.
That's exactly what I'm thinking about... Ripping old box out and redesigning/build new aero port box. I thought I could possibly get away with a 6" aero, but it doesn't sound like it now. Looks like an 8" for me... Good write up guys, I hope this keeps moving along. Learning some things here.
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
How would you even determine port length with 2 different sized ports?
You would make them both the same length and that length would be determined by the total port area between the two.
Builds:
That's what I was thinking.
see when I start building boxes for my subs I'm going to do a few different aero port ranging from 2-3 6" ports and 1 with a 10" port. Still working on an idea with 2 8" ports. The 6" ports will because its what the manufacturer suggested for round ports just to see how their suggestion works out.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I can only think of negatives when considering multiple sized ports.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Don't be a negative Nancy :-P
Seriously though, what are your concerns?
Builds:
i cant really understand why someone would purposely get aero ports, just so they could use less port area. aero ports are just crazy efficient, and purposely using them just to go with less port area seems like you are completely defeating the entire purpose of them. spend lots of money on a nice port, and completely defeat its purpose.
Owner of BigAss Ports
Resonances.
Would you not have to separate resonances based off of the two areas of the ports?
And then you get the harmonics of the ports getting worse and worse over every next f1*x?
Or would you just use this formula instead to find the resonance of the ports?
f1= velocity of sound divided by two times the length of the column?
With the area having no affect on the second (and third possibly) resonance of the ports?
Now for a tip I read a long time ago from some JBL papers. If you are going to be using a system where you are trying to get every last amp through those coils, you need design your system around the parameters of your speaker when it is hot not when it is cold, as the parameters are going to drastically change from this variable.
Then after you get a hot coil what does it do to the inside of the enclosure? That's right! It gets hot as well, which means you need to go about tuning based off of the temperature of the internal volume of the cavity. As the temperature of air changes the speed in which sound travels through it changes, to find this you need to use this formula.
For air, the average molecular mass for dry air is 28.95 gm/mol, and the adiabatic constant γ = 1.4.
I suppose people do this because they want to try to make stuff fit into the smallest space possible. I get your point, it just seems like a lot of folks don't have maximum performance as their top priority.
Builds:
this is something I understand. I was just simply asking because I once believed the aeroports can be smaller thing but found out that even though it can be smaller doesn't mean it should be smaller.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 536 Guests (See full list)
