KiKaZz74 Posted August 23, 2014 Report Posted August 23, 2014 That's the arauco plywood and then Baltic birch. I work there and we also have veneered MDf panels which is what I am using in my current box I'm building. There is also a treated MDF panel which I think I snagged up one on accident in the bargain area. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
fecupe2001 Posted August 24, 2014 Report Posted August 24, 2014 i would LOVE to see an spl challenge, same box built 3-4 times with different kind of wood metering on the termlab and clamping results, that would be interesting! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
hispls Posted August 24, 2014 Report Posted August 24, 2014 i would LOVE to see an spl challenge, same box built 3-4 times with different kind of wood metering on the termlab and clamping results, that would be interesting! Indeed. Someone in the industry told me they did direct test with identical boxes of both MDF and cheap particle board. The MDF outperformed particle board by over 1dB but after both were coated with resin they were dead equal. Also add to the list OSB. Use some epoxy resin between layers and paint with epoxy and it's working out quite well for me. Also working very well for a guy that does a 160 on the kick of his daily driver. I think the problem is there's no "silver bullet" of wood that doesn't need to be thick and/or braced. I've seen plenty of MDF flexing like a trailer in a tornado. The best solutions for lightweight and rigid become prohibitively expensive (think Carbon Fiber tubes) . There was some speculation on some composite wood made from Bamboo a few years ago, but I think that was also cost prohibitive (and I'm not sure how easy it is to work with). I KNOW hardwood isn't easy to work with.
Ritch40 Posted August 24, 2014 Report Posted August 24, 2014 I am in no way a box building expert,but, here are a few things i have learned over the years. A ton of this depends heavily on how the box will be finished(on the inside). my next box will have plenty of bracing. after thats in, i plan to glass the interior corners(other than in the port). there is a very good chance i will also lay a coat of resin to the entire inside of the box(excluding the port which will be primed and painted) as well. that application of resin would negate what ever lumber choices i have made. The one thing i will say, while rigid is VERY good, you dont want a material that is so rigid that it will crack or break under the stress subs will put the box under. If you plan to do very little to the inside of your enclosure, then you really need to watch what you use for acoustical reasons. If you plan to do a lot of work inside like i am ( like Steve Meade often does) then your lumber choice imho isnt quite as critical.
kingsuv Posted August 24, 2014 Report Posted August 24, 2014 You could look at using phenolic Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
Ritch40 Posted August 24, 2014 Report Posted August 24, 2014 You could look at using phenolic wouldnt that be cost prohibitive as well?
Hugh G. Rection Posted August 24, 2014 Report Posted August 24, 2014 ive spent quite a bit of time in the guitar and pro audio world, all of the best sounding cabinets ive ever heard in my life were built from poplar. Owner of BigAss Ports
Ritch40 Posted August 24, 2014 Report Posted August 24, 2014 ive spent quite a bit of time in the guitar and pro audio world, all of the best sounding cabinets ive ever heard in my life were built from poplar. i have to wonder if that has something to do with the frequency response of the combination of your guitars, pedals and the way those amps were built
Hugh G. Rection Posted August 24, 2014 Report Posted August 24, 2014 ive spent quite a bit of time in the guitar and pro audio world, all of the best sounding cabinets ive ever heard in my life were built from poplar. i have to wonder if that has something to do with the frequency response of the combination of your guitars, pedals and the way those amps were built well its not just guitar cabs. pro audio, home theater, heck lots of different things. Owner of BigAss Ports
Ritch40 Posted August 24, 2014 Report Posted August 24, 2014 ive spent quite a bit of time in the guitar and pro audio world, all of the best sounding cabinets ive ever heard in my life were built from poplar. i have to wonder if that has something to do with the frequency response of the combination of your guitars, pedals and the way those amps were built well its not just guitar cabs. pro audio, home theater, heck lots of different things. Interesting....it does have a pretty grain to it too
