Finally started a new project im my "new" car!
1998 Omega B
My plan is to keep building a bit over the winter and spring to get ready for next years car and car audio meets/competitions. This Isn't an spl oriented build as I want it to play low and awesome with a clear front stage, but I'll still do my best with what I end up getting. I'll be participating at least :)
What I get as far as equippment will be revealed as I get it. I have a plan, but I might change my mind so I won't say anything just yet!
What I am clear on so far is that I'm rebuilding my front doors, and that's where I'll start this project. The doors will house two 6.5"s each and I'll have a pair of tweets in either the a-pillars or in stock location if it'll fit. To begin with I'll see if my Tang Band speakers might work in a car, so you'll se those in the pics. So lets get to building :)
This is what I have to work with
Behind the panel and plastic
Teardown
Theese are the different parts the doors consists of, partly screwed and glued
The glue was sto strong so I couldn't just pull the old fabric off
On the bright side the resin etc. should get a good grip on this, might drill a few holes as well
Theese are the parts I'll be altering, the rest will be left stock
After I have my plan of attack, I'll get to making some speaker "rings"
Made a little sketchup drawing to figure out my dimentions
I spent som time making the first piece
When it's done I'll use it as a template to make the others. This is much easier with the right tools so I made my own little thrown together router table
Then I made the ruff cuts
Put on some double sided tape
Then let the flush trim bit do it's job
Theese will be the outer rings. I used a rabbeting bit to get my desired inner diameter
This is how they ended up with a little 45 for good looks
45'd the rear of the speaker holes
Done, just need to be glued together
Checking fitment
The depth is alowing me to add some sort of speaker grille
Just enough clearance for vinyl
That's all I have for now!
There will be updates as I make progress :P
nice. need the list of router buts you used.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
A small straight/plain router bit for the circle cutouts
Flush trim bit to copy parts
Chamfer bit to make 45s
Rabbeting bit to shrink parts
Update time :)
Figuring out placement, moved up 1cm from this20140906_173620_zpsd9csisl8.jpg
The point of no return
Building a base
Needed two more of theese
Put theese together with 4cm spacers at fiirst, but this isn't gonna work so I'll cut holes in the doors so I can shorten it down a bit. I think that would've been the best idea from the beginning.
Enden up with no spacing at all
Holes
Mounting for the "pod"
Getting there
One door ready for fabric and fibreglass, I'll do it while it's on the door so I'm sure to get good fitment.
Made a bit of progress on the other door as well
Only missing the little mdf ring, then I can mount the rest of the door panel and get it ready for glassing :)
A few minutes work later
Then It started to rain
After a little break I could continue
Got ome fleece
First staple
Top row done, was a bit easier access without the top halve on
Put it back on after I trimmed the fleece down
Completely stapled
After resin
That's all I got done today :)
Comments are welcome
Now that it's hard it seems to be strong enough for me to take it of the door to lay down some fibreglass.
Taken off and sanded down
Two layers of mat
It's coming along nicely I think :)
I have some more progress pics :)
Removed all excess fibreglass
Keeping the original mounting spots
Not even a full layer of filler and the shape is pretty much there
Continuing on the other door
Had to do have a look at it
If the resin actually hardens in this cold I'll be laying some fibreglass tonight :)
