I have uptades :)
I split the posts so there won't be too many pics on each page fiy.
Moving along
Almost done at this stage, there's was bit more filling and sanging work but no need for pics
Next I sat down to figure out further driver placements, and if I can even fit theese 4" fullranges in a reasonable matter.
It'll be close to this:
received_m_mid_1411043016544_06dce097c26
Tweeter goes here:
The drivers I'm using :) Will ba a 3-way setup with two 6.5" for midbass, one 4" mid and a 28mm silkdome tweeter on each door.
Next up I wanted to tackle the tast of running wires to the doors, the most annoying part of the whole build imo!
After a bit of teardown:
Had to get through here somehow
Luckily there's usually some unused pins:
The other part whas tricky to get out, but I got it eventually:
Pulles theese two pieces out of the connector and made some room for wires:
Three pair of wires in each door, fml:
It startet to get dark before I had it all back in place:
Started on pods for the fullrange drivers:
Here's a better picture of all the drivers:
Might have another update on equipment later tonight :)
nice work! those door pods are coming along great!
Hope they'll look as good as I want after vinyl!
This looks great man. I'm glad someone here finally showed that if you really take your time with your fleece and get it tight and wrinkleless it doesn't take much filler. Here lately more often that not you see a lot of installs where everyone just pulls the fleece really quick then cakes pounds of filler on there.
Yes, I SO agree with you!
  • Who's Online   1 Member, 0 Anonymous, 672 Guests (See full list)
