2 10s in a 4th with passive radiators
WadeTustian
Do you mean making a 4th order and substituting the vented side with a radiator? Or putting the radiators on the sealed side, which would sort of turn it into a 6th order.
Edit: I actually don't know if anyone has attempted doing either of those actually. I've seen some nutty enclosures designs.....
substituting a port for pr. just trying to find info on it really, not much out there
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Yes you could do it as long as the passive drones and subwoofers are together. For example,a simple 4th order bandpass enclosure made for 4 12" subwoofers,with one drone and driver on each side symmetrically. Honestly though,it is a PITA to get right because your passive drone can completely throw off tuning and output and cause unwanted frequency dips at certain frequencies.
Im sure there are software's that can calculate drone parameters for building 4th order passive bandpass enclosure.
I think it's doable. But two 12" PRs ain't gonna cut it. You want at least double the Vd in your PRs as you have in your powered drivers. Maybe a single 18 PR, or a pair of 15's. Gonna take some design work. I loved my PR setup, though it wasn't a bandpass.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
With all the work you'd go through building something like that just to get "no port noise" why not just go sealed with a lot of cone area?
It's not the same. And it's really not that much extra work.
What's not the same?
The work I'm referring to is for design, tuning, and rebuild. If the goal really just is to avoid port noise entirely, I stand by my statement that regular sealed would be the way to go, it is easier...I mean, that is assuming a properly designed vented is out lol.
A sealed box for 2 15s or 18s is going to work at least as well as the PR bandpass idea.
Don't get me wrong, the idea is very cool. But knowing Wade personally, I don't think its really worth the effort for the chance to build another fail box :/
Team NorthWestSPL
What tune are we going for here ???
Sound isn't the same.
IMO, a PR box is easier than any ported. As long as the initial design is good, which is simple, anything after that can be adjusted basically. For PRs, all you need to worry about is Vd. If you have enough, you're good. Tuning is simple and adjustable. Airspace on each side is the only tough part really.
I'd rather see a regular bass reflex with PRs than sealed. And shoot, I am confident I can help him design that easily, as long as he has enough space.
