Ninja_v1.0 Posted September 30, 2014 Report Share Posted September 30, 2014 which will be better on an electrical system option A or option B Option A: 1 amp that is doing 4k at 1ohm Option B 2 amps at 2 ohms that is doing 4k ( each amp doing 2k at 2 ohm for a total of 4k) we are looking for which option will be easier on the electrical system Go! edit: your electrical systems is the following ALT: 200amps charging at 13v HOT BATTS: 4D3100'S When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL Link to comment Share on other sites More sharing options...
JEFFYBOI Posted September 30, 2014 Report Share Posted September 30, 2014 Just was in the chat room listening to this. Running any amp @ a smaller load will be more efficient. Im going to keep it simple and say the 2 @ 2 ohm will be more efficient. "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 30, 2014 Report Share Posted September 30, 2014 Ignoring efficiency it should be the same I think... But with efficiency the 2 amps should be at least a little more efficient. Assuming you are comparing similar amps. I think! lol F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Ninja_v1.0 Posted September 30, 2014 Author Report Share Posted September 30, 2014 Ignoring efficiency it should be the same I think... But with efficiency the 2 amps should be at least a little more efficient. Assuming you are comparing similar amps. I think! lol yes amps are exactly the same When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL Link to comment Share on other sites More sharing options...
JEFFYBOI Posted September 30, 2014 Report Share Posted September 30, 2014 Ignoring efficiency it should be the same I think... But with efficiency the 2 amps should be at least a little more efficient. Assuming you are comparing similar amps. I think! lol He asked which would be easier on the electrical system so i think that falls under efficiency. They both may put out the same but when you get down to the little fine details the 2 vs 1 will be running much smoother and more efficient. "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS Link to comment Share on other sites More sharing options...
Ninja_v1.0 Posted September 30, 2014 Author Report Share Posted September 30, 2014 correct not looking for same power but which one will be easier achieving that power since electrical is weak in the application. When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL Link to comment Share on other sites More sharing options...
Wicks Posted September 30, 2014 Report Share Posted September 30, 2014 Probably very similar for the fact that the 2ohm setup will be more efficient then the 1ohm setup, but the 2ohm setup has two separate power supplies which will have some redundancies and inefficiencies itself. But I'd venture to say the benefit of staying at 2ohms will be the most efficient. Are you going to test out the scenario to see which is correct??? This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
will77530 Posted September 30, 2014 Report Share Posted September 30, 2014 assuming you are clamping the exact same numbers, they should be identical for your charging system but the 2ohm would be easier on the amps Link to comment Share on other sites More sharing options...
Ninja_v1.0 Posted September 30, 2014 Author Report Share Posted September 30, 2014 Probably very similar for the fact that the 2ohm setup will be more efficient then the 1ohm setup, but the 2ohm setup has two separate power supplies which will have some redundancies and inefficiencies itself. But I'd venture to say the benefit of staying at 2ohms will be the most efficient. Are you going to test out the scenario to see which is correct??? maybe.. with maybe a little bit more power than whats stated When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL Link to comment Share on other sites More sharing options...
audiofanaticz Posted September 30, 2014 Report Share Posted September 30, 2014 maybe pick up these books and give them a read! http://www.ceautoelectricsupply.com/wiringbooks.html Link to comment Share on other sites More sharing options...
