1 or 2 runs of 1/0 to rear battery
As i was gathering the last of stuff i needed to start installing my system , I bought 2 runs of 1/0 wire to run to the 2nd battery. Unfortunately i only got sent 1 of the runs , so i need either to buy more wire or just use 1 run for now . is a second run needed for 2500 watts ? Amps are fused 150 and 100 , pos wire is sky high 1/0 ofc under 15 foot between the front and extra battery .
That wire is rated at 300amps right?
One should be enough 2 would be better imo, room for upgrades.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
no such thing as too much electrical. as long as its charging right!
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
One will work 2.would be better but its up to you depends on if your going to upgrade down the road . In my eyes you can never have to much overkill on electrical.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Single run of 2/0 would be nice.
The demand means nothing.
If you have a stock alt, and put a 10k in the back, does that mean you need 4 runs to feed the 10k?
You just need to OVERKILL a bit, on WHAT YOU HAVE to play with.
If your alt does 100amps. The amp you have (demand) doesnt dictate runs? Why would it?
  • Who's Online   0 Members, 0 Anonymous, 1713 Guests (See full list)
