Ohio Generator alternators good output at idle?
Of course you would know more about what Im thinking then I do, lol
I was going to go with excessive amperage model which was also a great deal but its not putting out as much at idle and I have read some mixed things about the excessive amperage line, the dc powers were a lil expensive for me but If the performance was there I would have went with it just would be waiting a little longer and been a little lighter in the wallet for it
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
lolol reminds me of atomic stories
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
They are legit. But then again I run Mechman!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Just out of my own curiosity how much did they quote you? since you said it's cheaper than the other alts you listed prices for.
I'd get updated idle and full output numbers from all the others before I made a decision. That DC Power chart is over 4 years old, kind of outdated info at this point.
Different PLUG CODES also.,
And, ALT rpm is NOT engine RPM. Just sayin. :shrug:
i converted alternator rpm to engine rpm based on crank pulley diameter and pulleys on alternator.........................................
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Looks like you would want to go with a DC Power alternator from what you've found. Not that the 300A is going to perform the same as the 275A at idle... In some cases you actually lose idle amperage with a alternator rated at higher amps. You still didn't get an answer for your question.
