Dragonware Posted December 7, 2014 Report Posted December 7, 2014 Hi Guys Im a little confused how to use this. after I turn up my volume on the headunit and find its max...do I back the volume down when I move to the amps ? Or keep the volume at max.? Also all settings on the headunit are flat. Can i re set them after without cuasing problems ? What if I also have a line driver after the headunit, audio control matrix they have 3 gains one for front rear and sub, do I have to use those gains to set it self ? or the DD1 will help me ? I also have an Audio Control Epicenter between the line driver and my bass amp. can you tell me how to set this up ? last question should I ditch my bass knob from the amp if I am also using the bass control from the epicenter ? Thanks as detailed step by step will be appreciated since I am renting a DD1- i dont have time to play around. My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top
CNF Kevosinn Posted December 7, 2014 Report Posted December 7, 2014 check on D'amores website. the manual is on there *** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ ) "kevosinn's" astro van 8 custom Sundown Zv4 18's 4 Sundown scv 6000's CNF Distribution CNC parts Skyhigh wire some batteries SMD Meters and tools used on the installhttp://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/ 16,000 watt walled silverado build.http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/ 8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60TEAM CNF Distribution
ToNasty Posted December 7, 2014 Report Posted December 7, 2014 no, you leave the hu at its max volume before distorsion, than i like to use track 5 for the amps. I used to have a dd1. the directions are pretty clear ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
OrionStang Posted December 7, 2014 Report Posted December 7, 2014 http://www.damoreengineering.com/documents/Distortion%20Detector%20DD-1%20Ver.%205.pdf SMD Super Seller My Feedback Thread
Dragonware Posted December 7, 2014 Author Report Posted December 7, 2014 user manual doesnt state how to do this using a line driver. And im still confused if i should flaten out all my amp cross over frequencies before i do this My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top
OrionStang Posted December 7, 2014 Report Posted December 7, 2014 Yes it does. Set your head unit volume, then set the line driver gain, then set the amplifier gain. And yes, all crossovers should be set to open or full pass while setting. READ THE MANUAL. Its all there. SMD Super Seller My Feedback Thread
alaskanzx5 Posted December 7, 2014 Report Posted December 7, 2014 Step 1 Disconnect all speakers Step 2 Eq to flat, all gains all the way down all filters off Step 3 choose your track and play it Step 4 Find max volume Step 5 Starting with the gain closest to the head unit inline with the amp your dd-1 us connected to turn it up and set for no distortion. Do this all the way down the line to till you get to the last gain controller Step 6 Repeat steps 1-5 till all amps are done Step 7 Set eq and filters. If your using a bass boost or remote for the amp you can adjust it for no distortion and mark that spot. Do t turn it past that and its your choice to take said risk. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
philrab Posted December 8, 2014 Report Posted December 8, 2014 RTFMSMH 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
