Running wires through doors ?
If there is a molex plug there are usually empty sockets you can run a drill through to get more wires to the door.
Easiest way I've found regarding boots is to take both ends of the boot loose from the vehicle and compress it together so it's as short as possible. Then run some sort of fish tape (like the guys above have mentioned) through it while it's easier to manipulate from both sides. Snap it all back together when the wiring is done.
Static drops are my bag.
I've gone as far as cutting out the plugs a d retrofitting with boot from junk yards ... Looked great and unnoticeable when done ... That's what counts I reckon ??"
Yeah, i know it can be done but fuck..Yes it has a molex plug but seems imposable to get to from under the dash. If i remove the boot i might be able to drill a hole next to the molex but still keeping the wire in the boot..idk.Thanks though i wondered if i could pull the boot and get it to go back in. As soon as it gets a tad warmer out im going to tackle this, to cold out.
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Yeah...I might look into this if i cant figure it out. My 98 1500 was 1000% easier then this dodge
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Hope you don't have a newer Mazda. They decided to get cute and the "door boot" is a multipin connector. Half is clipped into the unibody, other half is attached to the door. To get wires through there, you have to drill a hole through the pin connector and run the wires through solidly, or utilize some unused pins. PITA no matter how you do it.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
What kind of car is it? You mentioned a Dodge, if it's anything like my Dakota I can show you how I did mine.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
2006 ram 1500...if you got photos or build log or anything i would appreciate it bro..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Wrong section
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
