What is everyone using to screw subs in??
Pioneerchuck
Big concrete screws when using MDF big deck screws on birch
@DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many
-TEAM WOBBLY WOOFERS-
4 18s MAKE YOU SCREAM!
I cant remember the exact name of the screws but they came in a pack of 10 and can hold 55 lbs apiece and are very coarse threaded.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Edit: Double post. Ill take a picture of the screws next time im at HD
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I'm using 1/4 20 threaded inserts with 1/4 20 bolts and lock washers this time. Had issues with t nuts comming off think they would be fine if u epoxy them in before you bolt in subs. Before that always used wood screws.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Another vote for the spax #14 screws. I've had bad luck with t-nuts. Had to cut/drill out my fair share. They're not for me
I personally make sure whatever type of fastner is used, that the head is FLAT. A lot of people are posting pics of tapered headed screws and those are just bad mojo, asking to break off.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
The Spax have an auto counter sinking head and honestly I wouldn't want that chewing up my sub frame even though its really a minimal thing. They also have a tapered head so they could be prone to breaking the head off the screw easier than a flat head screw due to pressure. I have in the distant past experienced screws with tapered heads such as drywall screws breaking at the head, so I switched to a flat head screw type and have never had an issue like that again.
  • Who's Online   1 Member, 0 Anonymous, 1817 Guests (See full list)
