90,000 Watt Daily Build Update
They will take a soundigital 16 each, so I would assume they will eat is 15k no problem. Doesn't get much dirtier than them I'm sure his amps are a little better and he has the backup with the lithiums
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Nice
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
hmmmmm ;)
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
My teams were the first ones built for a fourth had the gapped opened up an 7 spiders just ordered recones said I wanted the same an got only 5 spiders .. Build looks great were u located
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I want to go back to battery talk...from what I'm reading here and searching the interweb, if you had alternator power and car running...you should be able to get full output from this battery for as long as the alternator is running?
and even after shutting off the car, this battery delivers an almost linear power curve so that you should see same output until about 10-20% charge?
Confirmed. The alternator will keep charging the battery. So even while changing songs, people getting in and out for demos, taking a break, etc. That's how fast they charge.
6 15" SSA Evils
18 XS Power D3400s
Probably doesn't matter at this point, but why not enclose your battery house with thin sheet metal? Shoulda upgraded breaks wilwood maybe :)
Yeah, I may do that for these. And wilwood are out of my budget. LOL how horrible that sounds.
6 15" SSA Evils
18 XS Power D3400s
So probably different hard/soft spiders?
6 15" SSA Evils
18 XS Power D3400s
