Will a amp wired to 4 ohm still pull as much power as an amp wired at 1 ohm
interesting, so an amp that does 1200wrms at 4ohm 2ohm and 1ohm, should really put the same amount of strain on the electrical system no matter what impedance the amp see's....
Just like the topic title.
Example.
If I have a 1200 watt amp that does 800 watts a 4 ohms drawing lets say 80amps, then take same amp but wire at 1 ohm putting out 1200 watts. Would it still draw the same 80amp or would the amp draw be raised to say 100amps or so. Just an example so excuse the poor math if any lol.
To answer your question, the draw will change based on load. An amp that draws 80a at 4 ohm will draw more than 80 when you wire it down to 1.
This won't give you an exact number but if you're just looking for ballpark figures, think along these lines Voltage * amps = watts and to figure it in reverse watts/voltage = amps
It isn't anything you can take to the bank for many reasons (efficiency, duty cycle etc.), but it gives you an idea on how it works.
I think the question the OP is asking is this:
is 800 watts roughly the same amperage requirement at 800watts @1ohm vs. 800 watts @2ohms.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I've always wondered this.
If you had a 2.5 Korean board. That will do 2500 rms at 1ohm. But let's say you grab a 5k Korean board that does 2500rms at 2ohm, or a 7.5k Korean board that does 2.5k at 4ohm. How will they all strain your electrical system? Similar? Or is it truly better to have bigger amps running at higher ohm loads.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Snafu has already answer this
So who would spend the money for a 10k and run it at 4 ohms? Or any other amp,and not run it to what its capable of doing?
Depends on what it's being used for, there is more to an amp than just wattage.
those crazy SQ people do that kinda stuff. maybe not with 10k but they run amps at higher nominal loads to lower distortion and such.
Of course lower nominal means less efficiency, but I wonder if you ignore efficiency if the amperage requirement is close.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 804 Guests (See full list)
