Doubling come area is a 3 dB increase.
Doubling wattage is a 3 dB increase.
It takes 10 dB to sound twice as loud.
You won't notice a 3 dB increase on music.
Redesign your box after you research done about how to even build a good one.
Not true. Maybe in theory land it is true, but not in practice.
I have tested that theory many times with myself and friends.
I have done variations of change in 0.5 dB to 5 dB changes and right around 4 dB on music is where everyone can tell the instant change. These tests aren't 100 percent in a controlled environment, and haven't exceeded roughly 100 dB.
I have even gotten it to where if I used 1 dB increments I lowered the output by 15 dB and the participant had no clue until I shot the volume back up in one change.
Krakin's Home Dipole Project
After 145 dbs every 3 db is noticeable difference
Doubling power doesn't = 3 dbs increase it all depends on the installation if had up to 5 dbs to as low as .5 db increase when doubleing power
To the op no matter what you do you will get use to the bass and will always just want a little bit more
Measured power?
Or double the amplifiers?
With no changes what so ever to the install?
A 3dB boost is in ideal conditions and is the maximum you gain by doubling power.
So if that's the case why does a 150 and a 155 feel and sound like whole different worlds?
I shouldn't notice unless I went from a vehicle that did 50's to one that does 60's right?
But fact is you can and do notice a difference at less than a 10 db increase.
Sound=/= feel.
Ears=/= body.
In a car it might sound quite louder because of different vibrations (dash rattling, windows,...) that the sound pressure causes.
That last sentence doesn't even make sense if you've read his comment properly.
Tanks guys ima build another box and tune to 32/33 hz and see what happens.....is 80^2 of port good enough?
Start a new thread in the Enclosures section and post your max dimensions current vehicle, equipment, desired tuning etc...
Someone will assist you with a box design.
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
All I will say, midway through last year, I had an amp I was doing a 155.3 on, switched to another amp and did a 156.2. Without telling my teammates, other than, just get in and take a listen... EVERY single one of them could tell easily it was louder than before (155.3). This was only a .9 increase. Was more violent, played lower, more choke and chest pressure, the whole shibang. Maybe .2-.5 or so but a dB is a dB. Maybe it is interpreted differently at high pressure levels.... I dunno.
Measured power?
Or double the amplifiers? good catch sorry double amplifiers i did not measure power output
With no changes what so ever to the install? no other changes at all
A 3dB boost is in ideal conditions and is the maximum you gain by doubling power. still gain over 5 dbs with double the amplifiers and the amps were at a high nominal ohm load when i added the second
Sound=/= feel.
Ears=/= body.
Another thing is when people talk about others being 1-2+ DB lower but SOUNDING louder. Install/enclosure makes a world of difference.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   0 Members, 0 Anonymous, 942 Guests (See full list)
