fx4trucker Posted March 12, 2015 Report Posted March 12, 2015 Ok i just hooked up my memphis amp to the head unit. Hooked up my speakers a set of hertz hsk 165xl .running active. Well when i switch it to network only the tweeters were playing... But when in standerd mode it all plays fine.. Amp is set up with twts on ch 1&2 mids ch3&4 Any reson why it was doing this? alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers. 1. set is in the a-pilors 1. memphis mojo 2500 watt amp 1. rockford fosgate t2 15" dual 2 ohm wired to 4 ohm . seeing 600 watts 1. realm audio 600 watt 4ch
reedal Posted March 13, 2015 Report Posted March 13, 2015 Check to see if mids are muted on HU. Go to network 1 and press selection lever until it reads mid HPF/LPF, and if it says muted then press the rotary switch and it should unmute. I can't think of all the proper terms for the switches right now, sorry. Hope you understand what I'm saying. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
OrionStang Posted March 13, 2015 Report Posted March 13, 2015 Also double check the xover settings on the deck and the amp. Do you have 2 sets of rcas run? SMD Super Seller My Feedback Thread
Miguels Posted March 13, 2015 Report Posted March 13, 2015 Also double check the xover settings on the deck and the amp. Do you have 2 sets of rcas run? lmao this will be funny if it only has a pair my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
OrionStang Posted March 13, 2015 Report Posted March 13, 2015 It could happen though, the unit sums channels in standard mode. SMD Super Seller My Feedback Thread
reedal Posted March 13, 2015 Report Posted March 13, 2015 I thought the same thing about the RCA's, but I wanted to give benefit of the doubt on that. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
OrionStang Posted March 13, 2015 Report Posted March 13, 2015 The MUTE thing makes sense, too. Sounds like OP needs to read the manual IMO. SMD Super Seller My Feedback Thread
TaylorFade Posted March 14, 2015 Report Posted March 14, 2015 You probably have your RCA's backwards. Pioneer is retarded and put the tweeters on the "rear" channels.
Kyblack76 Posted March 15, 2015 Report Posted March 15, 2015 You probably have your RCA's backwards. Pioneer is retarded and put the tweeters on the "rear" channels. Yup. I did that actually. Also. When swapping from network to standard and vice versa, I'd reset the unit. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
