I have only one RCA connecting to the amp which Im going to fix... I have had a broken RCA for a while now. I scoped the one I have connected and its a clean signal... even if its only 1.5 volts.
Its been like that for a while now.... Maybe it is screwing with the amp.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
wire lower
done
wire to .35 or what ever...
Lol man I only have one sub I cant wire to .35. I get the point about how they should read lower which I figured is usually the case... but they still read 2.3-2.4.
how are you wired at one ohm if you have dual 2.4 coils ?
Do they make dual 2.4's ?
im a lil lost?
"Checked coils on sub (read 2.4ohm each)"
It reads more like 1.3 ohm at the terminals. i said 1 ohm earlier i meant 1.3...
They are dual 2 ohm subs with a DCR of 2.4 I should have been more specific
weird...
to me, a dual 2 would read 1.4 dcr per coil...........
dual one would read .7 per coil....
DCR should read LOWER .. not higher
That is only with Fi, Crossfire, AA etc. type subs mainly. DC, Sundown, blah blah blah, and so on all read right at or .1-.2 over.
I understand Thomas.
But, how is he seeing a 2.4 coil on this sundown sub?
So if it is a dual 2, and hes wired at 1 ohm... why would his voltage drop ?
Ill bet with his mayhem, he was making more power... ill bet it was a was a dual one,... at .7 dcr, and he was acutally at .35dcr
know what i mean?
I understand completely.... and who is thomas... lol.
OP, I would check RCA connection to make sure they are tight. Im my truck, along with other teammates have seen similar stuff with no power output and ended up being a loose RCA.
my bad... wrong name.... lol
also,... the voltage at 32v seems odd to.... i agree
lol, it is Travis.
Where are you reading voltage from? What's your AC voltage on the output of your amp if you play a 40hz tone full volume?
I didnt get numbers for the AC output but I can tomorrow. I didnt see anything out of the ordinary when I checked earlier however.
Need solid numbers to work with. Voltage at the amp being DMM on the set screws at the amp for your power wire
For the AC voltage output I get 32 volts at full tilt on a 30 hz test tone.... which seems low.
What amp? By that math the gain is set to put out in the 1000w neighborhood. Might need to turn your gain up more
Sundown 2000d. I'll try turning up the gain a bit... it's at like 4/9 right now so right under half.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
You have an oscope right? Crank that sucker. There's a link in my sig to some test tones you can use too. Try the -7.5 or -5db 40hz track. -5db will be safer, but you aren't running that much power to the mayhem so if you are adventurous, try the -7.5 track ;)
I wish I was having a no voltage drop issue
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
It's the Tantric HD but I'll try the tones.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
at this point I think it's more of an amp/Rca issue possibly.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
My bad! Even still, my statement regarding power and tones still applies :)
