Slinky Posted April 7, 2008 Report Posted April 7, 2008 there nothin wrong with just letting it airdry. should be fine Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
cyclotron_burst Posted April 8, 2008 Report Posted April 8, 2008 if you just let it air dry it might cause corrosion on the board itself..and thats no good....I work in a PC repair depot repairing systemboards all day long...I always use SLX Denatured Alcohol to clean the boards.... Quote
Slinky Posted April 8, 2008 Report Posted April 8, 2008 if you just let it air dry it might cause corrosion on the board itself..and thats no good....I work in a PC repair depot repairing systemboards all day long...I always use SLX Denatured Alcohol to clean the boards.... itll corode that fast? Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Torres Posted April 8, 2008 Report Posted April 8, 2008 maybe not fast...but if you just let it air dry, it could corrode overtime. you might already know this also, but dont heat it up to dry it out. just in case the thought crossed your mind unless it's already dry and you just need to clean the residue...then nm Quote
AI James Posted April 8, 2008 Report Posted April 8, 2008 if you just let it air dry it might cause corrosion on the board itself..and thats no good....I work in a PC repair depot repairing systemboards all day long...I always use SLX Denatured Alcohol to clean the boards.... so do i and the chances are like the chances of getting struck by lightning. just like ground straps and anti static bags, ive NEVER not just plain handled a system card and ive NEVER grounded it out and killed it. Quote
Slinky Posted April 8, 2008 Report Posted April 8, 2008 so do i and the chances are like the chances of getting struck by lightning.just like ground straps and anti static bags, ive NEVER not just plain handled a system card and ive NEVER grounded it out and killed it. game..set..match.. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
cyclotron_burst Posted April 8, 2008 Report Posted April 8, 2008 yea the only time I actually use a wrist strap is when the boss makes me cause we have visitors.....and I dont just swap parts I actually replace componets on circut boards and have never had a problem with static. Quote
David Posted April 25, 2008 Author Report Posted April 25, 2008 well after tearin it down 100% cleaned everything spot less, put it back together and sata is gone. Im now looking for a decent p4 478pin board. any suggestions, been outa teh pc market for a minute. I just need this to get me buy for a while, once the car is closer to completion I will build me a new pc. Quote
