robby512 Posted March 25, 2015 Report Posted March 25, 2015 looking at all the t/s parameters for different subs trying to understand if there is a way to use those numbers to pick the best loudest hardest hitting sub? or do they just give you a general idea?
Krakin Posted March 25, 2015 Report Posted March 25, 2015 They do and don't. They are pretty much used for designing enclosures. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
kirill007 Posted March 25, 2015 Report Posted March 25, 2015 Modeling... Thinking is the root of all problems... You ALWAYS get what you pay for.
MrBigs63' Posted March 25, 2015 Report Posted March 25, 2015 Certain parameters will give you little hints, but you should only really look at the parameters when shopping for a woofer if you know that you can only go with a certain type of box. For example, If you know for sure that you only have room for a sealed box, then you might want to look into a woofer with a higher QTS for better sealed performance. Many others that know a lot more about T/S parameters may let you know some other things to look for, but I still haven't found a person that was willing to explain all of them to me.
Triticum Agricolam Posted March 25, 2015 Report Posted March 25, 2015 If you are so inclined, you can put a LOT of effort into sub selection. T/S parameters are part of that, but they aren't everything. Also not all manufactures publish full specs and those specs aren't always accurate. Here is a run down of what the different T/S parameters are and what they do: Qms - A mechanical / pneumatic "quality" number that truthfully doesn't lend a great deal of insight to helping you choose a subwoofer for most applications. It is affected by physical properties that you can look at more accurately (IMO) through other specs, such as moving mass (look at Mms), suspension compliance (look at Vas, or a Cms curve), etc. Qes - An electrical "quality" number... think of it instead as a good indicator of motor strength. Do you need a subwoofer with a strong motor? You might be surprised to learn that high strength isn't always a good thing. (hint: Look at EBP... or check out Qts. ) The smaller the number, the stronger the motor. (also, the smaller the number, the smaller the enclosure, quite often - but it is just one factor in that equation ) Qts - A calculated number, using Qes and Qms - for a "total quality" number. I sort of downplayed Qms's importance earlier... and even in this calculation, Qes so far outweighs Qms in this calculation, that Qts actually ends up quite close in value to Qes - and small adjustments to Qes affect Qts much more than even large adjustments to Qms would have. Anyway - this is an important one. One of the "main 3" you need to calculate enclosure size/type/performance. (along with Fs and Vas). Qts mainly can tell you what sort of application your subwoofer is compatible in: High Qts value? Very compatible in a sealed enclosure. Low Qts value? Very compatible in a vented enclosure. Qts around 0.45 (middle of the road)? Design compromise to work OK in either, rather than outstanding in one and bad in the other. It's very helpful that way. Fs - Resonant frequency. This is the frequency the subwoofer most easily resonates at - and in free air, has the highest impedence (actual resistance with a subwoofer varies both with frequency and enclosure - it's not just "4 ohms" or whatever - it may rise up over 40 ohms, in fact, at points!) at that frequency. What it's useful for looking at is in judging how low a subwoofer can play. A low Fs means the subwoofer will be able to play lower... ...but means it won't be as efficient in the higher frequencies either. So maybe not always a good thing - or rather, something you need to compromise with realistically, to target your own personal tastes... loud? Or low? Or a little of both? EBP - EBP stands for "efficiency bandwidth product", and it's just a helpful calculation, to expand on what Qts tells you with regard to the "what box is it good with?" question. EBP = Fs / Qes. Simple calculation. It includes Fs in the equation, because in a sealed box, the subwoofer needs a low Fs in order to play low frequencies. In a vented box however, you can design the enclosure so that it helps extend the low frequencies farther than a sealed box, so Fs isn't as important for that. Qes is important because in a vented enclosure, you have higher pressure forces at work - so you need a stronger motor to contend with them. In a sealed box, that stronger motor will drive up the system resonance (a box/sub combination version of Fs), making for bad sealed performance. The actual EBP number tells you whether it's good in sealed or vented... EBP at 50 or below, sub is best suited to sealed. EBP higher than about 80, sub is best suited to vented boxes. EBP in between, sub is OK in either sealed or vented. Vas - Suspension compliance. This number represents the "volume of air" that provides the same "spring" force as the suspension system on the subwoofer. What it means to you, is that a smaller Vas makes for smaller enclosures. What it also means, is that a smaller Vas makes for lower efficiency, and a higher system resonance as well. Mms - Moving mass. The cone and coil, and surround and spider even have a mass associated with them. The higher the moving mass, the lower the efficiency of the speaker - but the lower the Fs as well. A designer adjusts these when deciding how thick of a cone (of course a thick cone may be rigid too, which is a good thing), or what cone material to use. This is one reason why "high output" SPL subs are actually much less efficient than cheapo subs. Cheapo subs can be louder than SPL subs? Yes, unless you have the wattage to make that SPL sub scream, and that cheapo sub melt. Xmax - Here's a good one... represents the linear excursion of the subwoofer, from the "at rest" position, moving in one direction, until the measurement limit is met. AT least that's how SOME manufacturers list Xmax. Others list it as "peak to peak" - which obviously doubles the value. Others list Xmax when they really mean Xmech (like Polk, for example). Some perform a calculation of voice coil winding length compared to the thickness of the top plate - that's the traditional method, and it's not horrible, it's just also not "apples to apples". So you have to know what you are looking at, when comparing. (and by "linear" - that means that the motor strength spec doesn't change, and suspension compliance spec doesn't change, as excursion changes. When it does begin to change, that marks the end of "linear" excursion) Xsus - This is the suspension component of "Xmax". Subwoofers may be "suspension limited", having a suspension that has a smaller range of linear excursion capability than the motor has. Xmax is always the smaller of the two values. Xmag - This is the motor strength component of "Xmax". Subwoofers may be "motor limited", having a motor that has a smaller range of linear excursion capability than the suspension has. Xmax is always the smaller of the two values. BL curve - This is an actual plot of motor strength with respect to excursion - simple plot really - motor strength on the Y-axis, excursion shown on the X-axis (and generally shows both positive and negative excursion - so traditional subwoofers with traditional architectures can look quite a bit like parabolas on these plots). Very helpful for understanding visually exactly HOW LINEAR a motor can be - and even how gradually it rolls off after that limit. Cms curve - The same thing as the BL curve, but shows suspension compliance with respect to excursion... so you can see exactly how linear the suspension is, and what it's limits are, where they are reached, and even how graduallly it rolls off after that limit. Re - This is just the DC resistance measurement of the coil. It's always a bit less than the "nominal impedence", and really doesn't tell you too much, other than "this is the lowest the impedence will ever dip to, on the impedence curve". (at some frequencies, impedence may rise up very high - a 4 ohm speaker might hit 50 ohms at Fs!) Le - Inductance is potentially an important thing to look at. a voice coil is a coil of wire - and so resembles an inductor. What does an inductor do? It resists changes in current direction and flow. What does a speaker do? It changes direction and frequency as quickly as the music throws those changes at it. So - basically you want your inductance to be as low as possible. Also... an inductor is a 6dB/octave low pass crossover - so at some point, inductance could be high enough that it prevents the speaker from playing frequencies higher than a certain point - the speaker itself prevents it - the lower the inductance, the higher the speaker is capable of playing. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Genesis730 Posted March 26, 2015 Report Posted March 26, 2015 Can this be suggested for sticky? Although a quick Google could probably explain most T/S parameters this is an excellent and easy to understand explanation of all these (to some foreign-like) numbers! Excellent write up, thanks!!
Joe X Posted March 26, 2015 Report Posted March 26, 2015 looking at all the t/s parameters for different subs trying to understand if there is a way to use those numbers to pick the best loudest hardest hitting sub? or do they just give you a general idea? You can find the same subwoofer performing differently in different setups (cars, boxes amps..etc). T/S only defines the sub.
