JScustoms05suburban Posted March 25, 2015 Report Posted March 25, 2015 Anybody else have that belt squeak in between gears with quad alts? It's an 05 burban with the 5.3l, and I'd love to get this shit to stop squeaking. Aftermarket tensioner, or different belt, (I'm using gates green stripe atm), or any real suggestion would be awesome. Thanks 3 350 amp 6 phase js alts 6 custom sundown 18s 4 ft1 tweets 8 8" pwx mids 18 g31 agm batts 2 crescendo 12k 1 american bass gt3200.4 1 jl slash 300/4 ~600 feet of 1/0 ofc knu
JScustoms05suburban Posted March 25, 2015 Author Report Posted March 25, 2015 Sorry double post. 3 350 amp 6 phase js alts 6 custom sundown 18s 4 ft1 tweets 8 8" pwx mids 18 g31 agm batts 2 crescendo 12k 1 american bass gt3200.4 1 jl slash 300/4 ~600 feet of 1/0 ofc knu
n8ball2013 Posted March 25, 2015 Report Posted March 25, 2015 Mine does it too with duals. Hard 1-2 or 2-3s THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted March 25, 2015 Report Posted March 25, 2015 common as balls.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
dolarbilz Posted March 25, 2015 Report Posted March 25, 2015 I belive its a common thing.squeak between shifts I can handle its when you have it all the time
SnowDrifter Posted March 25, 2015 Report Posted March 25, 2015 What belt do you have? Mine is manual tension so I can put it as tight as I need to avoid slippage. However... Look into the gates HD belts. Get the shortest one you can possibly fit, that way your your tensioner is wound as tight as it can. You can also see if you can track down a stronger/stiffer belt tensioner ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
audiofanaticz Posted March 25, 2015 Report Posted March 25, 2015 mine squeel when i get on the gas when the truck is shifting gears, and i have 3 alts. Best bet is to figure out if you can add additional idler pulley to tighten up the belt wrap around the alternator pulleys.
