audiofanaticz Posted March 26, 2015 Report Posted March 26, 2015 You need ones that are offset... http://www.droppinhzcaraudio.com/toolmaker-1-0-to-4ga-reducer-w-offset-pair/ I already linked him those oh well i guess.. Hopefully they will fit side by side and those rubber pieces keep them from arching against each other. LOL
Broke_Audio_Addict Posted March 26, 2015 Report Posted March 26, 2015 Get rid of that 300 amp fuse too and get one much smaller, I'd start with a 100 amp. Each wire should have its own fuse as well not a shared fuse. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
kirill007 Posted March 26, 2015 Report Posted March 26, 2015 Oh my god. This picture + the question why the wire is burning= Thinking is the root of all problems... You ALWAYS get what you pay for.
MrSkippyJ Posted March 26, 2015 Report Posted March 26, 2015 What is that extra ground wire connected at the amp for? That little wire melted the tape. There really is no reason for 0g wire in that amp, save your self some trouble and get some 4g wire and use it. Especially that close to the battery which is connected to the front battery with 0g. Like someone else said as well, get a separate fuse for each wire. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Broke_Audio_Addict Posted March 26, 2015 Report Posted March 26, 2015 Also you really should run a turn on relay for those remote wires That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Flip_one Posted March 26, 2015 Author Report Posted March 26, 2015 I've had 4ga wire from the second battery to the amp before but it was worse, at first the power 4ga wire will burn up so I took it out and put 0ga then the ground 4ga burned up so I also put 0ga... With the 0ga power and ground wires works just fine for about 2 months then when I turn it up loud thats when the 0ga ground starts to melt. Other than that the amp works perfect.
Flip_one Posted March 26, 2015 Author Report Posted March 26, 2015 Also, i use to have a 150a fuse and it would blow it, even a 200a fuse will blow too, the guy at the shop told me that JL amps pull way too much power thats why I had to put a 300a fuse
Broke_Audio_Addict Posted March 26, 2015 Report Posted March 26, 2015 That guy is an idiot, there is something wrong with the amp or the install. I'd suggest finding a new shop that actually knows what they are doing. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
kirill007 Posted March 26, 2015 Report Posted March 26, 2015 That guy is an idiot, there is something wrong with the amp or the install. I'd suggest finding a new shop that actually knows what they are doing. Agree, I'm thinking there is more chance that there is something wrong in the install then the amp. You are shorting out somewhere after the fuse. Thinking is the root of all problems... You ALWAYS get what you pay for.
ImaNoob Posted March 26, 2015 Report Posted March 26, 2015 Looks like the short is in that small wire cutting through into the zero, scary stuff man.. 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
