45s in all corners of a wall?
im designing and very soon building a wall for 4-HDC4 15s and would like to learn about putting 45s in all the corners to "improve airflow". now i do plan to coat the entire inside with resin and sand to either 3000 or 4000 grit for smooth as glass finish for those extra few db. but wanted to see if adding the 45 will improve the db at all, or lower port noise or anything. i have a 3D render on google sketchup of the wall and i can upload pics if requested.
about the wall:
-4 HDC4.0 15s
-2 Q1-4500D.1 amps
-16.75ft^3 net volume before woofer displacment
-270in^2 port area 20" deep for 36hz tuning.
-All walls will be 2x4s with mdf inside and some internal bracing
-walled from the B-piller back in a 2004 jeep grand cherokee 4.7L v8
plain with no 45s
render with the 45s
you're wasting a LOT of time
-45s in every corner
-resining the whole inside to seal
-sanding to 4000
unless you're going for every hundredth, hell, thousandth of a dB.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
-sanding to 4000
I get a "round over" or some "angle help" here and there........
What i do love, is the smooth transition....
Look at this shit..... its a mirror...
https://www.youtube.com/watch?v=WBxPHBo5lqc
99% of the time 45s hurt loudness but YOU won't know for sure unless you test it for your car..
No I here this all the time .... To improve air flow..... Like the air is flowing like water sorry subs don't make air "flow" it shakes the fucking shit out of air at a fast pace ....
That's why when people put things in there port it does not shoot it out but instead makes it float the air is getting moved back and forth not just out so there is no "flow"
Take a half filled water bottle and shake it as fast as you can that's what subs are doing to the air
Smooth doesn't always make for better flow.
Krakin's Home Dipole Project
Your dealing with aerodynamics. 45s can help in some cases, but they can also hurt in some cases. The best thing to do is test both ways and see.
Making things nice and smooth helps though. Just go to world finals someday and notice all the loud guys with how they wax and buff the insides of their walls with parrifin wax.
Owner of BigAss Ports
im no expert but air in a sub encosure is a cushion or suspension. if you put a bunch of 45 and a glass smooth surface it might be bad. I mean, air doesnt just flow out the port, it flows both ways following the stroke of the driver. You are just pressurizing and depressurizing and chamber. Dont confuse this with something like a combustion cylinder where air flow is basically one direction.
I'm thinking that haveing some resistance is probably a good thing otherwise you will lose some of that suspension the air in the box provides.
well im not chasing the db as its more for show and fun then competition, but ive heard alot of places "claim" that sanding to 3000+ grit allows sound to "flow" along the surface with out getting distorted. im not new to car audio but i am new to walls and systems like the one im building. its over double the power ive dealt with before and if im spending $6k on a system i want to do it right...
so recommendations would be to resin and sand a little, test it... then add 45s and see if i like it more, if not take them out... or resin them in if i like it better?
well....
I like it over a 45 everywhere on the planet....... i like it period...
and i see what your saying..... Me? id put a 2x4 on all the wall sides..... and bust it up a bit......
Smooth surface CANT hurt..... No way... Not from "what ive seen, and whos told me to do it"..
I also like the "round over" idea port baffle, and back driver baffle style......
but.. meh......
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
