expanding foam in the heat?
Yesterday I sprayed some expanding foam on my roof in my tahoe and it was pretty hot out. It all just melted and dripped to the floor. Is this supposed to be used in a cool place? I tried to search and could find anything about not using it in the heat. Also the cans I have are not expired but are about to be expired on april 4th, could that be the problem? I sprayed some outside in the shade and it worked fine.
It's going to drip unless it sets up put tape over the openings or go really really slow
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
no... ( i ran into this when it was 110 out)
chill it some...
you want it come out "thick".. Put it in your fridge when you go to work..........
When its HOT as nuts.. it will not adhere the same... nor will it "space up".....
had many peeps tell me i did it wrong.......... Keep it on the colder side of room temp.... it will work better... trust me...
(if it "poured out" when you where pushing it.. its not right..)
I'll try the tape. I just thought it would expand and then harden but it expanded and then melted.
spraying expanding foam in the heat.. N8 will never have that problem
did you shake the cans? if its liquid like or foamy?
Yea, i shook it for almost a minute since it sais to shake for 30 seconds. It sprayed out foamy and then just turned into liquid and dripped and only a little hardened.
Expanding foam and heat :(
This is exactly what happened to me.
some wise ppl told me to throw the can in the freezer for a bit, and/or spray at night.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
chill it some...
It didnt pour out, it expanded and then melted.
also.. yes.. drip..FILL gaps..YES.. you want that... you want to see "hangers" or stalacties"...
that said.. if it RUNS out... it WILL NOT foam up.......
cool it down some.... for best use...
I'll try this but when i searched i read that people were saying to warm up the can because it wouldn't work if it was cold. i'm confused now
