Beyma Midbass?
hoit
Hello all,
I'm considering getting a couple of 8 inch mid bass drivers to be mounted in my front doors. I saw these, and wanted to get some feedback from anyone who uses these, or have used them before. Any thoughts? Also considering looking into other brands...This is NOT a vs. thread in anyway, just looking at some options and choices. Thanks in advance!
http/:www.ebay.com/itm/2-Beyma-PRO8MI-8-inch-400-Watt-RMS-200-each-4 Ohm-Mid-bass-midrange-Speakers-/141631649391?pt=LH_DefaultDomain_0&hash=item20f9e7766f
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
I have those mids. They get really loud but really lack in the low end. Overall clarity is pretty good too.... they sound good loud
If you don't want to play lower than 150hz they will be fine.
OP, both of these are true for most pro audio drivers. Just make sure you're aware what you're shopping for.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
I have the Precision Power three way set (65C3) and 2 X10s...just looking for a gap filler (100-3000 Hz). Not trying to spend a shit-ton either. Any other suggestions guys?
Singer 220 amp alt
I feel your system may just need a good tuning.You should need no other drivers to fill that gap.those 3 ways are sweet.
You may be right dolarbilz, I'm just running passive...not quite ready to make the move to active.
Singer 220 amp alt
hmmm...even in passive your set up should be pretty sweet (relative) but I'm curious what others say. Tuned
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
So how are you going to be running these new mids passive? Also, why would you need a gap filler between 100 and 3kHz if you have a three way set? I think you've got some tuning issues that need to be resolved. Throwing drivers at your current problem isn't the right solution.
Explain your setup as it stands.
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
