Can you mix agm and lead cell
This challenger in doing a build on. The guy wants to run his stock lead cell in parallel with his xp3000. I said to wait until we have a agm to replace stock, because they will drain each other and eventually he would have a paper weight. Any insight, he don't believe me.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
The lower voltage lead acid will drain the xp3000 down until they reach equilibrium of the lowest voltage between the 2
Also don't quote me on it but I believe in internal resistance on the lead acid is greater and has some effect on draw
All it will do is reduce the life of the batteries... Battery should have an expected life of 7 years unless abused so instead of 7 years you might get only 4 or 5 years maybe less with it paired with a lead Batt...
Dunno where on here I read it but I think you can run a battery isolator between the two to keep them from hurting each other.
I'm aware of isolators. The issue is, we don't want to spend anymore money. So he doesn't want an isolator, but I'm suggesting a replacement for stock battery.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
tell him you're right (agm/lead acid drain) and to stop being a cheap ass.
its worth it to do it right the first time or risk blowing up an amp or worse
just hook them up. i doubt the length he has them, nothing noticeable will happen.
you wont blow the amps, or hurth anything. it will reduce the life of the battery with the higher resting voltage. and actually help the battery with the lower resting voltage.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Well lower resting batt is probably no more than $200, whereas the reserve is worth over double that.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
