RooTxBeeR Posted May 31, 2015 Author Report Posted May 31, 2015 He'll be fine. Just keep the wet cell battery under the hood, and the AGM in the cabin or trunk. The problem is each battery rests at different voltages and the one that rests lower will leach the higher resting voltage. Don't store the car for more than 2 weeks or so with the batts connected, as said above. They are both in the trunk. I am well aware of the process of degradation here, just wanted to make sure it would be fine as a daily. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
im45pl Posted June 3, 2015 Report Posted June 3, 2015 o.k so i am facing the same situation here with my build.. i have 12 agm group 31 batts and 4 non agm 200ah batts, my car will only be for shows and demos and being a van i am limited to alt power so i wanted to add the extra batts for reserve capacity... if while in between shows i disconnect the non agm batts and use the intellicharger for top up charging i should be o.k? cheers - didnt want to start a new thread for the same question TEAM DC AUSTRALIA My_Build_Log
MrSkippyJ Posted June 3, 2015 Report Posted June 3, 2015 Didn't realize vans were limited in alt power F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Bump4life Posted June 3, 2015 Report Posted June 3, 2015 o.k so i am facing the same situation here with my build.. i have 12 agm group 31 batts and 4 non agm 200ah batts, my car will only be for shows and demos and being a van i am limited to alt power so i wanted to add the extra batts for reserve capacity... if while in between shows i disconnect the non agm batts and use the intellicharger for top up charging i should be o.k? cheers - didnt want to start a new thread for the same question yes if its not daily driven disconnect the non agm from the agm between shows and charge each bank seperately Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
ALPINE408 Posted June 10, 2015 Report Posted June 10, 2015 its worth it to do it right the first time or risk blowing up an amp or worse In what possible way can mixing the batts blow an amp.... Please explain.. I'm still waiting to hear how you could possibly blow an amp "or worse" by mixing the batts Have you ever had your woofers blown?
RooTxBeeR Posted June 11, 2015 Author Report Posted June 11, 2015 o.k so i am facing the same situation here with my build.. i have 12 agm group 31 batts and 4 non agm 200ah batts, my car will only be for shows and demos and being a van i am limited to alt power so i wanted to add the extra batts for reserve capacity... if while in between shows i disconnect the non agm batts and use the intellicharger for top up charging i should be o.k? cheers - didnt want to start a new thread for the same question No problem m8, you got an answer too. Bass on On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
khinds94 Posted June 11, 2015 Report Posted June 11, 2015 Doing the exact same thing right now with a lead cell and xp2000 both rest fine lol. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
ALPINE408 Posted June 12, 2015 Report Posted June 12, 2015 its worth it to do it right the first time or risk blowing up an amp or worse In what possible way can mixing the batts blow an amp.... Please explain.. I'm still waiting to hear how you could possibly blow an amp "or worse" by mixing the batts Anybody? Should I start a new thread on this? Have you ever had your woofers blown?
Bump4life Posted June 12, 2015 Report Posted June 12, 2015 its worth it to do it right the first time or risk blowing up an amp or worse In what possible way can mixing the batts blow an amp.... Please explain.. I'm still waiting to hear how you could possibly blow an amp "or worse" by mixing the batts Anybody? Should I start a new thread on this? you cant blow an amp by mixing batteries. or worse. there Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
