Tuba HT Subwoofer Build
Here I am sitting here twitching for a video
Soon, I still have some work to do and need to get some more gasket tape before I start putting the watts to it.
At least its starting to look a little more complete. I trimmed up all the edges:
Here it is with the access cover temporarily in place:
Builds:
Pl also goes brittle and starts falling apart after a couple years.
Well I got this thing finished up today. Here are a few more pics:
I'm working on uploading a video. I'll post the link as soon as it gets done uploading.
Builds:
So here is the video, let me warn you that recording videos isn't really my thing, so adjust your expectations accordingly:
https://youtu.be/Thye25Iieno
The video not very impressive to hear, I only have the sub hooked up and its low-passed at 100 Hz, the song I was playing has its bass note at about 31 hz, which my pathetic iphone camera mic doesn't pick up at all. Its pretty damn loud in real life, you just can't really tell by the video. I think I need to put a new battery in my AMM-1 too. The sub was getting around 130-150 watts, and that was at a frequency that is right in the middle of an impedance dip for the enclosure.
I've got an experimental series tuned 6th-order bandpass box to build and then I'm going to haul everything outside for some ground plane measurements. I'm going to do some compare and contrast between a handful of different subs I've built and I'll be sure to post the results here for everyone to see.
Builds:
You built this enclosure to be loud ??
I was kinda thinking this was more for accuracy in a 5.1 / 7.1 environment ...
I built it to be efficient and accurate, kinda two sides to the same coin in this situation. Higher efficiency give me the same SPL on less power, less power means less driver excursion, and less excursion generally means less distortion.
Builds:
Isn't that like the reasoning behind line arrays too?
More speakers doing less work equals more efficient and less distortion?
Not the reason for most of them, they are used for acoustic dispersion patterns.
Depending on the array you can "beam" sound to more specific location and farther distances with a less dB loss per doubling of distance than a conventional speaker. This allows for less wattage needed for a higher SPL at a farther distance, which is why they are so common in large venues.
Krakin's Home Dipole Project
  • Who's Online   0 Members, 0 Anonymous, 1995 Guests (See full list)
