I have a 1985 Monte Carlo SS and I'm very interested in putting 1 10" subwoofer in the trunk. The main reason is because I'm getting tired of hearing local people scream and holler about the diameter of a subwoofer (just like tv's), not realizing that enclosure, electrical, and the specs of the sub mean more (if the model isn't the same).
My budget for the sub is around $300 and I'll be having the box built by a design from a builder on the forums. I'm considering getting the HDC 3.0 10" from soundqubed (I'm open to suggestions) and pairing it with my old Hifonics2008D with is rated at 2k rms but I know I won't see that. I have a 200a alternator, optima red top, and big 3. The trunk will be sound deadened. I'd like to keep the enclosure as small as possible while giving it all the airspace it needs to get as loud as it can be.
I know that "loud" is relative, so let's say, would you be able to hear that bass from 1,000 ft away (a city block)?
Learning Everyday.
Pioneer AVH-P4000DVD
Alpine SPS-610C
BXI-2008D
(2) SWR-1242D / Ported
I think the hdc3 will work fine for your application. Very good budget subs IMO.
System:
Pioneer DEH-8400BH
4 Alpine Type R 6.5's
4 Soundqubed PA 6.5's
4 Soundqubed Supertweets
Hifonics BRX 640.4
Crescendo S800/4
2 Soundqubed Q1-3500.1s strapped @1ohm
2 Soundqubed HDC4 18's
11 Cubes net @37hz (Subs up, port back)
2 DC Power 250 HD's
1 DC Power 300 SPX
DC Power triple alt bracket
5 Kinetik HC 1800's
4 runs of 1/0 OFC power cables
4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket
iPad Air in dash
300+ sq ft or sound deadening
I would suggest the hdc3's. had 2 on only about 2200 watts and its about as loud as my fi sp4 15
Fi Team 18's (4)
Crossfire 16k
Crossfire 400.4 & 800.4
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
Thanks guys
do you think one would suffice?
Learning Everyday.
Alpine SPS-610C
BXI-2008D
Thanks guys
Depends on your goals. I have 2 HDS3 10's on a T1500 @ 1 ohm and close to 2k in a subs & port facing forward enclosure. Facing into the cab from the trunk and the subs could easily take more power. Subs sound good, so depends on your goals.
soundqubed stuff.... LOVES big boxes.
I don't really want a big box. The Monte Carlo has a "shelf" in the trunk and I'd like to keep the front of the box flush with the opening in the trunk like this...
I'll go back and measure the space I want to stay in though.
Learning Everyday.
Alpine SPS-610C
BXI-2008D
