Sundown SA 8 v2 t-line or just ported?
I'm picking up one of these. Anyone have experience with one of these ? I'd like to build a t-line for it but I don't know what to tune it to for best results, and I'm not very good at the math . Help please ! LOL
Tune the tline to 35 Hz (8 feet of port length) with a port area of 30 in^2.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
You could most likely achieve whatever your goal is with a simple ported enclosure.
Now if you are just doing it to play around then go for it.
I can't help with specs or anything like that as I don't do designs.
Do a T-line if you have the space. Typically you tune a T-line to the driver's Fs with a port area equal to the driver's Sd.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
I would say T-line because I had my V1 in a T-line on 600 watts and it was pretty nasty for a little 8...
T-line will be much larger than standard ported though
Team MaxRetribution
Si Vis Pacem Parabellum
Personal preference I don't care for t lines unless the sub has a low fs. The roll off is ridiculous
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I see the fs on these is 40, which is gonna make a pretty high tuned box , which in my opinion is not what I would like. I was hoping for tuning around 35 hz or so. So maybe a normal ported would work out a little better? But the 1/4 wave should be louder right?
where do you see an Fs of 40? From the sundown website they are 34.6 for D2 and 35.95 for D4....
http://sundownaudio.com/index.php/products/discontinued/item/sa-8v2.html
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I was looking at the v3 I just realized. Thanks for the correction. So based on the fs of 35 that would be just fine by me. So, what kind of dimensions do I need to follow for port size and length ?
  • Who's Online   0 Members, 0 Anonymous, 2036 Guests (See full list)
