Mechman Alternators
Mechman 320s series billet unit issue
I bought a mechman 320 s billet hairpin alternator for my ford mustang late last year,just got it in maybe a month ago or so been working fine (kinda) I had hoped to get 14.5 volts out of the unit(requested 14.5 when i ordered) when i was seeing 13.9at max
anyways a couple weeks ago i dropped in a different stereo and everything was going fine (i think) i am only running at 2 ohms on amp right now so getting maybe 3000 watts out at the most
at 2 ohm load on amplifier im dropping into high 12s (not terrible) snaps right back
now today I was driving to work and i looked down and seen voltage ranging from 13.5 to 15 volts,jumping around even with radio down,wasnt doing it all the time but here and there
I could also hear a bit of whirring from up by the engine ( i suspect it was the alternator bearings maybe?)
so i popped the hood and this is what i saw
the bolt on the positive output of alternator had turned white i believe this bolt was copper colored when i got it with the alternator???, is there any explanation why that would be? and also why the voltage would be jumping around? possible regulator gone bad on alternator?
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
I don't think the nut is copper tbh. I just did. Mine.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yea maybe it wasnt, i see a bit of corrosion developing there though.
still want to know about the weird voltage issue though
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
not to mention alternator never charged at idle even thoguh idle information crank pulley size was provided
i have tried gettn the car to idle a bit higher thru tps manipulation but hasnt worked yet
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
What volt meter were you using to measure that it was jumping around from 13-15 while driving to work?
Not true.. Depends who makes it and If it's hairpin
Op does the voltage jump when you accelerate? Did you replace the tensioner and a smaller belt? Slip is always the issue
yea belt was replaced with smaller,tensioner good, voltage during acceleration is fine i was driving along at 60 mph and watchin voltage fluctuate,this was showing on a stinger voltmeter i now have a digital multimeter installed and will check tonight on way to work
alternator is a hairpin,belt wrap is very good and dont see any black dust anywhere
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
  • Who's Online   0 Members, 0 Anonymous, 1704 Guests (See full list)
