6.5 PWX Crescendos BIG CONCERNS
Picked up 4 crescendo 6.5's for my 14 corolla, will be putting 2 in front doors in stock spots and 2 in rear deck stock spots.
Car comes with 6 speaker system, with two tweeters build into the corner of the front windows facing the cabin.
Question is this I will be running these on my Rockford Fosgate P400x4 Punch
http://www.rockfordfosgate.com/products/details/p400x4
Since its a relatively efficient amp and the birth sheet says 563 watts should I be running each set of nendos on 1 channel to maximize the power instead of 50 to each then its doubled of course? (If my understanding is correct), effectively running it in 2 channels instead of 4, are there draw backs to doing this? will it effect anything drastically?
Also will this effect my stock tweeters in the front stage with too much power? or do i need to buy crossovers for them?
also let's say i run them each on 1 channel since ill be not utilizing even half there power potential will I be able to go lower on the hertz range closer to 40 hrtz? instead of nendos tech sheet saying 80 hrtz +?
Not running a sub till next season i think so trying to make the best of this configuration for a little bit of time.
Thanks ahead of time guys.
  • 1 month later...
bump
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
If you are running a 6.5" driver, I would highly suggest not running them below 80 htz no matter how many watts you throw at them ...
Your bottom end response will depend on how well you seal up your doors during installation ...
Ok, if you plan to operate 6 speakers and keep your balance and fader functions ... you will need 6 channels of amplifier power. Unless ... you passive the tweeters with the front doors and run the rear doors off of channels 3 & 4.
Make sense ???
if you run the amp in 2 channels instead of 4 and and run the same 4 speakers that are 4ohms you would actually loose power since the amp isn't 2 ohm stable while bridged. You would have to connect the speakers in series resulting in a 8 ohm load, rockford doesn't say how much power it gives out bridged but i assume it somewhere are 50 watts.
it sounds like you are using oem amp for oem tweets, no real solution to make that louder
the 6.5 pwx has a freq response of down to 83 hz, that doesn't mean set your crossover to 80hz it means set your crossover at 100-125hz since it's a slope not just a cutoff at that freq.
You would have to connect the speakers in parallel resulting in a 8 ohm load.
No. Series would increase impedance, not parallel.
Really ???
Really ???
yes they're loud speakers not subs, they do put out a bit of midbass but at the minimum i'd set the crossover at 100hz, 125hz if you're giving it rated power.
you can put on a 80 hz test tone at low volume and adjust your crossover until you stop picking up the 80hz tone.
Mine soundqubed PA's are high-passed at 80 and have no issues with reproducing that on rated power. Freq response stops at 100hz. What's the explanation on that?
Really ???
Yea man, my bad thinking these were sub bass drivers and not midbass drivers ... guess I'm a f##king noob ??? But correct me if I'm wrong, but the average midbass driver should be set up to play 240 htz down to 80 htz with 12 db of slope ??? I mean if you set them around 100 / 125 ... what's gonna make up the difference if the subs are normally set at 70 htz low pass ???
  • Who's Online   0 Members, 0 Anonymous, 758 Guests (See full list)
