XP battery-truth is?
I was messaging XS power about some battery bracket info and was told information I thought was interesting. I was told the reason XP batteries are secondary is because the case is not able to take the heat like the d batts can...well this scared me because I have an XP under the hood in the second battery tray as my secondary batt... I have removed it since, the plan is to build a sheetmetal battery box and line outside with heat barrier and then reinstall. Anyone ever ran a XP in high heat area of under hood?
2011 Silverado Ext Cab
Pioneer 6100NEX
SkyHigh 1/0
XS Power
Polk db521 coax in rear
Skar 6.5 Components
Sundown SAE1000-D
Fosgate P600x4
Personally I wouldn't do it. Stick to the D series under the hood at all. XS Power recommended it too. $.02
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Most people dont have room under the hood, with the exception of trucks & some suv's so for the average consumer this isn't a issue. But nice to know & i'd swap it out aswell like stated above unless you live in cold state
Yep...just love dropping 200 on a battery to not use it and buy another 200 battery because XS doesn't care to share that info before purchasing, only when you contact them will you get the truth of why.
Pioneer 6100NEX
SkyHigh 1/0
XS Power
Skar 6.5 Components
Sundown SAE1000-D
Fosgate P600x4
I research everything I buy before buying it.
I mean they have the batteries broke down into starting batteries and secondary batteries..
Its also not a hidden fact and very known not to use the xp batteries under the hood, simple research or asking a question will tell you this.
Purchased well before I was on this form but yep would have loved to ask the question. And okay its broken down to primary and secondary....there are vehicles that have a secondary battery tray under the hood. If XS would just put on their website, " Do not use XP series near any high heat environment" then all would be good. The average customer shouldn't have to join a forum to find out the product they purchased will not work. Would love for someone from XS to jump on here and give real numbers to likely hood of battery going bad from being under the hood as I assume they have tested this.
Pioneer 6100NEX
SkyHigh 1/0
XS Power
Skar 6.5 Components
Sundown SAE1000-D
Fosgate P600x4
Like I said. When you go to choose the battery for your vehicle an xp won't pop up. That should have been a good clue
You mean to tell me when I went to look for a secondary battery I shouldn't of looked under their secondary battery list? My mind is blown.
Pioneer 6100NEX
SkyHigh 1/0
XS Power
Skar 6.5 Components
Sundown SAE1000-D
Fosgate P600x4
  • Who's Online   0 Members, 0 Anonymous, 831 Guests (See full list)
