When I push on my sub it makes a grinding-ish feel/noise?
LoweredA34
Alright, so let's say I put gain at about 1/4.
I also have a bass knob, how should that be utilized?
Onto my HU (Kenwood DDX272) in your opinions, what should my audio settings be for Equalizer and the Subwoofer Level (It goes to +10) ? I know loudness and bass boost is a big no no.
And X'over, I have that set for 100 hz at mids and highs since stock speakers. And my sub is set to through for bass, and as I just learned, my amp will actually limit the subwoofer from playing to high.
Makes me love my gap more and more and more and more. :)
only coil grind ive heard in the last 5 years, was from kennys bubbled level 6's.
you sure it wasnt from the triple joints?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
throw away the bass knob :)
Also set your low pass to lik3 60-80
throw away the bass knob? whuuuuuu- wait... full bass all the time? ok lol
And by low pass, you mean on my Headunit for the woofer right? What about the "Subwoofer Level" adjuster? It goes from -10 all the way up to +10.
All the bass knob is doing is controlling the bass boost on the amp. A bass knob connected via "phone cable" is just a bass boost.
If you really want to control your amplifier with a knob consider the PAC-LC1 and install it inline with your RCAs. This just controls the signal from your headunit to the amp.
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
Wow, I never knew that. Jesus I make one thread and learn at least 3 new things, pretty cool.
if this grinding sound happens when you push on it a little your coil has begun to unwind from too much heat
if this is the case, the sub is blown sorry
every bass knob i have seen does NOT control boost. it takes where the gain is set(thats all the way up/max) and lets you adjust the gain until that point. even my hifonics that says bass remote does not control bass boost. if you have your amp set correctly then when you turn the knob all the way down the subs should be almost un-noticeable. if you turn it all the way up thats where your gain it set.
one way to know if you have a gain control knob is to plug in the knob. turn it all the way up. then unplug it. if it sounds exactly the same its a gain knob. if it were a bass boost knob then when you unplug it the bass boost would go away.
Follow Seth Sharer Designs on Facebook for more frequent updates!
New build coming soon!
20 6.5s wall on two massive drago 5ks
and the pac is a good knob. but may induce some noise and/or distortion. a better one(suprisingly) is the scoshe knob
  • Who's Online   0 Members, 0 Anonymous, 934 Guests (See full list)
