Amp Test Tuesday - Sundown SAZ 1500-D Amp Guts and Dyno Runs @ 1, .8 and .5 Ohms
I have been wanting to do this for a while now. I realize i SORTA already tested this amp but since it was way before i had an official "test bench", it never got a fair shake compared to all the other amps i have tested. I had previously used 2 8ga wires on positive and 2 8 ga wires on the negative (all i had close by lol) for power wire. It was also on one single XS Power D1400 Battery. I also don't think i even tested this amp at 1ohm. There also was no "Amp Test Tuesday".
So let me officially make this official and put this on the new bench for a REAL "Amp Test Tuesday".
Power supply used: 10 XS Power D1400 14v Batteries.
XS Power PSC 60a Intellicharger/power Supply (turned OFF during runs, only turned on in between to top batteries off).
Tested the amp at 1 ohm to see if it can do rated power. I really didn't need to do .8 and .5 ohms, but since i did that on the last test, i just wanted to show the difference. I really tortured this amp and it took it like a champ!! got nice and warm but that is to be expected!
All gains set with the SMD DD-1 Plus to 8db of overlap. That really doesn't matter too much but i think it's a nice little gain setting to start with on woofers.
So what type of numbers do you guys think it will do? There is NINE numbers since i tested in all 3 modes at 3 different impedance's. Video will be uploading in about 1 hour.
see that there
.5 will bring beast number all will be over 1700 which adds up to over 5k when you add the 3 test together
Miguel what are you smoking?... must be some good shit I want some too :D
learn to read.. he said 9 test buddy.. even if it does rated on all 3 test of each its at 4500 watts (per load)
Edited by Miguels
4133 1 ohm
4754 .8 ohm
5112 .5 ohm
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Here ya go...i also posted a copy on the 2nd post to keep all the pics and the vid close by each other.
Follow my Tweet (Twitter)
That is nuts. I knew it would be good but not that good. I had a Sundown 1200 and it was a great amp.
sundown amps are legit.
Every time I hear the word Legit this is in my head.
Edited by Hotdog
  • Who's Online   1 Member, 0 Anonymous, 752 Guests (See full list)
