You are over thinking it. 1 layer of deadener and a layer of ccf will be more than enough. You'd be suprised how much 1 layer of good deadener will fix it
What's wrong with overthinking a problem before it happens :unknw:
No need for 2 layers as mentioned.
I'll get a feel for it when the headliner comes down.. my 2 shallow JL's on a 1k amp would flex the roof so 7x the power on 4 12's should make it get nasty. Others have warned me about how bad the flex is on a titan roof. Won't really know until all is said and done I guess but thanks for the advice.
I was one of the others that warned you about the Titan. They suck to pressurize and they flex bad. You should go about deadening the right way though, not just throwing layer after layer.
It fine to over think but you are over thinking way to much. Which is ok but we are trying to help you. Even second skin said. My roof flexed from rain droops. Silverados have horrible roofs. 1 layer of shit deadener worked great. I'm not even going to add anynore.
I didn't even cover my roof 100% and it's fine as well. My truck does pressurize pretty well and I don't need any additional deadener.
Don't overkill it. I did, it's a waste of money.
Don't forget to check your email for a sweet SMD forum member sale coming out soon to save you some cash!!!
Happy Halloween 2015
In between your haunted house tours, spooky parties, and costume filled trick or treating days this weekend enjoy some SPOOKTACULAR savings on all Second Skin Products. These scary savings won’t last long so make sure to order your high quality American made products between October 28th and November 2nd to save 10-20% at checkout.
Use the codes below at our check out screen to take your savings off the products:
Orders above $125 get 10% off using FRIGHT10SMD
Orders above $275 get 15% off using SCREAM15SMD
Orders above $450 get 20% off using GOBLIN20SMD
(Not including Shipping)
Use the above codes at WWW.SECONDSKINAUDIO.COM to get your savings applied to your products at check out. Have a fun and safe Halloween weekend and don’t forget to get those orders in by Monday November 2nd, 2015!!!
