Passive radiators
5.5 - 6.0 cubes is awfully big for a single 15".
Have you tried modeling the output in any box simulation software to see what kind of frequency response you are going to get?
I got the 5.5-6.0 cu ft estimate from psi so I assume there reasonably correct seeing as how it's their radiator and unfortunately my dog has recently chewed through my laptop charger and im left with no computer but friends ones occasionally but I would love to put it in winisd 8 or something it's 2 psi passive radiators 15" and a crescendo forte 15" also I can post full specs of the radiators in just a moment
The box should be built according to the woofer's specs, not the PR's.
Can you also post the woofers T/S parameters?
This. A PR is a port, just a somewhat lossy one. You're trading the weight of air in a traditional port for the mass on the PR. Therefore, you're still building for the driver. You get away with a smaller box because you don't have the additional size of the port in the box. Otherwise, net volume should be the same. For the most part anyway.
PSI's PRs are good, I did a build with a pair of 15" drivers and 18" PRs. Loved that setup. Just make sure you secure that box, because it's serious biz when those things get moving. Also, if at all possible, mount the PRs on opposite sides.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
I thought radiators were to help if the box was too small, like the big bad SMD towers? The highest tuning would be the box with no radiators and go down from there?
Yes, to my understanding it is small as compared to the vented enclosure seeing as how a PR takes place of a vent I would compare the box sizes and the pr box would achieve lower, flatter response in a smaller box than with port also never have port noise
PRs save port displacement. The lower tuning you want the greater box size savings you get.
  • 1 month later...
Does a person just use the net volume required plus displacements for calculating the volume to use for a PR enclosure?
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
Yup.
Builds:
One other question i have is do you wire the driver in phase or out of phase?
I'm confused by that because i'm not sure if the PR's would be more effective in or out of phase.
Sorry Scorpion for hijacking your thread with my questions.
No problem haha any information on radiator boxes for the future helpful i unfortunately don't know the answer to your in phase or out of phase question but thanks for adding to the topic
You don't wire passive radiators
i meant the subwoofer driver if my post is what you are refering too.
Using a passive radiator has no effect on how you wire the sub.
If you are mounting the sub normally (magnet inside the box) wire it normally, if you are invert mounting the sub (magnet out), reverse the the polarity.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
