SCATHED Posted February 7, 2016 Author Report Posted February 7, 2016 10's in the proper box will walk on 12's that are in too small of a box But I can fit two DC level 3 12s
MrSkippyJ Posted February 7, 2016 Report Posted February 7, 2016 How many cubic feet do you have total? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Joe X Posted February 7, 2016 Report Posted February 7, 2016 10's in the proper box will walk on 12's that are in too small of a box But I can fit two DC level 3 12s What you are probably needing to check is mounting depth as it is a single cab.
ShadeTreeMechanic Posted February 7, 2016 Report Posted February 7, 2016 Don't forget that the displacement of the subs and port need to be figured into your available volume. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
SCATHED Posted February 7, 2016 Author Report Posted February 7, 2016 I appreciate you all for helping me. I went out and got some measurements and here is what I have to work with. It includes space for the port to breathe. Width: 42 Height: 21 Bottom depth: 10 Top depth: 6 According to my calculations that is 2.97 cubic feet before any displacement. I plan on using aero ports or an octoport as well as a double front baffle but flush mounting the subs to conserve space
SCATHED Posted February 7, 2016 Author Report Posted February 7, 2016 10's in the proper box will walk on 12's that are in too small of a box But I can fit two DC level 3 12s What you are probably needing to check is mounting depth as it is a single cab. Right now I have an Fi Bl which has a mounting depth of 6.75
Triticum Agricolam Posted February 7, 2016 Report Posted February 7, 2016 I appreciate you all for helping me. I went out and got some measurements and here is what I have to work with. It includes space for the port to breathe. Width: 42 Height: 21 Bottom depth: 10 Top depth: 6 According to my calculations that is 2.97 cubic feet before any displacement. I plan on using aero ports or an octoport as well as a double front baffle but flush mounting the subs to conserve space You aren't to fit two 12"s in that space with good results. Not even close. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
khinds94 Posted February 7, 2016 Report Posted February 7, 2016 I appreciate you all for helping me. I went out and got some measurements and here is what I have to work with. It includes space for the port to breathe. Width: 42 Height: 21 Bottom depth: 10 Top depth: 6 According to my calculations that is 2.97 cubic feet before any displacement. I plan on using aero ports or an octoport as well as a double front baffle but flush mounting the subs to conserve space You aren't to fit two 12"s in that space with good results. Not even close. Yup that's 1 12 airspace. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
CleanSierra Posted February 7, 2016 Report Posted February 7, 2016 You might be able to get 2 10s in there if you feed them 1 cube each after displacements. Im not the one you want to try to troll. Just a fyi for you.
ShadeTreeMechanic Posted February 7, 2016 Report Posted February 7, 2016 How about 3 8s? If you did 2 12s then the output would suffer. Maybe find a way to get more volume. Move the seat forward a little? Build a box section to extend under the seat to increase volume? It can be any shape at all. Put them in the bed and do a blow through? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
