browser keeps crashing so this will be done in sections.
Let me start with saying this build was done in the sub 20 temperatures with occasional snow showers. I only had 3 days to complete build due to long work hours so it was kinda rushed! I came here looking for ideas on a new build to upgrade from my original 4 kicker comp cvr's and this is the results!
160 Ft" of 2/0 EB-Flex welding cable
2 XS D3100's
Sky High fuse blocks
Sky High 200 amp fuses
Sky High 1/0 oversided copper lugs
Sky High shrink tube
1 set of aluminum battery blocks
I'll do body filler all day every day, but this reinforced, fortified fucking kitty hair can kiss my balls.
Sundown NS1 V2 6500 watt amp
2 Fi Sp4 12's duel 1 ohm voice coils with additional cooling
370 amp Singer alt. Instruction stated to go with a 1" shorter belt but i opted to go with a larger idler pully due to a shorter belt being a hassle to find. I finally found one through jegs but but with a 3 week leave time i think not.
Subs all mounted up. Triple baffle with subs recessed 1" for a cleaner look. Though the screws holding the front face on ruin that. Did this to keep the front removable in case i ever needed to access the speakers or re-tune port. I did forget to take a pick of the back of the box, I used threaded rod as terminals on rear of box to hook the speaker wire too! Subs are wired to a 1 ohm load.
Port installed. Tuned to 35 hz, didnt want to go too low!
This in my opinion was the most tedious part of the install, though I think it turned out well if i must say. Kinda got shorted on shrink tube by 2 pieces which really upset me at the time but owell.
Amp mounted and wired up. All ready to go!
My first attempt at making a video ended up in a confrontation with an upset land owner, notice me freaking out at the end of the video wasnt sure what to do at the time. Video was taken with my cell phone so excuse the quality. In this video you can notice the B-pillar flexing and the windshield flex and this is the only video that picked up the windshield flexing. Though i must say this phone does this system absolutely no justice.
https://www.youtube.com/watch?v=Y5pc9EiElm8
Switched locations to as far away from people as i could get got a couple more videos but again phone is not picking up everything flexing and have no clue why unless it hase something to do with the frame rate the phone records with
https://www.youtube.com/watch?v=CyyAPYlkv3U
BUT BUT AGAIN I get another visitor! Might I mention I am on a dead end dirt road that has no houses on it, nothing but hunting land for miles and this is what i get!
Lovely day!
2 x 12" subs in a single cab..... Im patiently waiting on the video
hey look at that... they popped up while I was posting this comment!
this video is private..... something went wrong!... I guess still patiently waiting
Every freakin thing in the truck is shaking and you cant see any of it in a video. Its loud as hell i promise, which i guess the warning should somewhat prove that!
dammmit man
getting down for sure and a half. South Carolina? I'm gonna have to see if I can get my buddy Hunter to check this out. He's going to NOPI nationals, I'll tell him to keep and eye out if you go.
dammmit man
im on the other side of South Carolina, 5 hour drive from there! Wont be able to make that one...
