Maxwell ultra/super caps
Sounds good. Ill have to try it and really read over bumps write up on then so i dont blow shit up. Its definitely something i want to try since im gona start another build on my 95 gmc. Would like to have one good batt up front and maybe just caps in the back for the truck. Im only gona be running around 3k (fsd 2600)
Where can I buy these sexy things?
A: At the moment, loose SuperCELLs are direct to consumer only by contacting XS Power at info@xspowerbatteries or by calling 865-688-5953. They will be available for direct purchase on our website at 4xspower.com very soon.
I think you have to sign a waiver on case you well you know.
Still learning but have started gathering.
Not sure if I remember correctly but Daniel told me that a single bank is good enough as 200 ah worth of batteries
they cant be compared to batteries. I said each bank is good for 200 amps continuous draw. any more and they start to heat too much.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
XS has said before it would be mainly for there competitors and people who know what theyre doing. theres plenty of room for error with caps and if you short them the amount of power let loose is way greater than a battery. they just wanna be sure that whoever is going to buy them is going to be safe
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
they will sell the bank to anyone.. they wont sell the caps on their own unless you know what you are doing and sign a waver
Q: I’m too scared to work with raw ultracaps, will you offer anything for me in the future?
A: Yes, the release of the XS Power SuperCell is mainly to showcase the component parts of our upcoming SuperCell Modules. We have been working on these for nearly a year and a half, and hope to be able to have them ready for official release this summer. The modules will be available through our normal dealer base and will be safe and easy to use for users of any experience level.
Well I just hopped on this band wagon so to speak I have a single bank (6) 2.7 3000f maxwell caps arriving tomorrow, I have copper bars waiting on their arrival and this post has answered SOME of my questions prior to installing them.
On using the 1% 100ohm resistors do I need to get a specific wattage rating on them or? And since I am going to use the resistors its just on between each + and - pair so I would need 3 resistors correct?
Also I am seeing 5% resistors not able to find 1%.
http://www.amazon.com/E-Projects-Resistors-Watt-100R-Pieces/dp/B00BVCCA90/ref=sr_1_1?ie=UTF8&qid=1459858442&sr=8-1&keywords=100+ohm+1%25+resistor
Does the wattage rating on the resistor matter also?
Thanks!
Edit I found these.
http://www.ebay.com/itm/50pcs-100-ohm-resistor-1-4-watt-1-metal-film-through-hole-US-Seller-/251442093136?hash=item3a8b1ddc50:g:Jv4AAMXQlgtS76ro
and these.
http://www.ebay.com/itm/100-NEW-XICON-METAL-FILM-RESISTORS-430OHM-430-OHM-1-4W-1-/322035110886?hash=item4afac9d3e6:m:m-W3TFq4U8x1zqVE1pcNzgA
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Well I am going to wire mine after a 500 amp relay so they don't get dragged down in voltage when the vehicle is off. As for the need for resistors or the balancing circuit from another topic on here the general feeling I get is that in large instances, such as 5+ banks you surely SHOULD be using a balancing circuit however in my case of a single bank I think it will be fine without it, but I will be getting the resistors just in case.
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
