baron_of_bass Posted March 21, 2016 Report Posted March 21, 2016 So I'm doing a build in which l be using a 3 way crossover: AudioControl 6XS. FYI: This is not an active set-up. I'm thinking of using these crossover points, does anybody see anything wrong with the xover points below: 4" comps 100hz and up 6.5" comps 50hz and up And the woofers will be 2 Fi fully loaded Q's I was thing of setting the xover point from 15hz to 50hz Below are the specs for the components. Team Bass-Hz
bcbrassard Posted March 21, 2016 Report Posted March 21, 2016 I wouldn't run that 4" @ 100hz. Seems a bit low to me. More like 250-300 as a starting point. But thats me. Just trial and error i guess. I had a pair of CDT 6.5 midbass driver that claimed it could play down to 40hz but it didnt like 60-70 hz very much. Played ok in the 80-100hax well.
baron_of_bass Posted March 21, 2016 Author Report Posted March 21, 2016 I wouldn't run that 4" @ 100hz. Seems a bit low to me. More like 250-300 as a starting point. But thats me. Just trial and error i guess. I had a pair of CDT 6.5 midbass driver that claimed it could play down to 40hz but it didnt like 60-70 hz very much. Played ok in the 80-100hax well. I was a little skeptical on their claim of a 100hz freq response. What about all the other 6.5s and subs? Btw, Thanks for the info! Team Bass-Hz
ALPINE408 Posted March 21, 2016 Report Posted March 21, 2016 http://education.lenardaudio.com/en/06_x-over.htmlXover basics easy read to ..... read all tabs and this is a great base line to start it has the ranges you should be in for the size of speakers you are using again this is just a starting point as every environment is different and needs fine tuning Have you ever had your woofers blown?
baron_of_bass Posted March 21, 2016 Author Report Posted March 21, 2016 http://education.lenardaudio.com/en/06_x-over.html Xover basics easy read to ..... read all tabs and this is a great base line to start Thanks alpine, I'll read it tonight Team Bass-Hz
bcbrassard Posted March 22, 2016 Report Posted March 22, 2016 Good info in there. Thanks for posting.
notorious97200 Posted March 22, 2016 Report Posted March 22, 2016 15 Hz to 50 Hz for the bass? Hum... Let your sub play from 80-100 Hz and lower. Why would you use your SSF at 15 Hz ?!!! Human can't hear under 20 Hz usually. Set the SSF a few Herz under the port tuning. Or at 25 Hz if you're running a big (for your sub) sealed box. I can't see your 6.5" speakers plays that low : I would try 80 Hz for the HPF. and a much higher crossover point for the smaller speakers. Good luck. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
OrionStang Posted March 22, 2016 Report Posted March 22, 2016 Those 6.5s can handle 60 just fine. My last setup, before selling, was going to be sub lpf 50, woofer hpf 60/lpf 300, mid hpf 350/lpf 4500, tweeters hpf 4800. So many variables, just gotta get them in and start messing around. SMD Super Seller My Feedback Thread
baron_of_bass Posted March 22, 2016 Author Report Posted March 22, 2016 Things are a bit different wth the AudioControl 6XS, it doesn't have your traditional "knob dial" to adjust your frequencies. It uses "crossover modules". The fact that this is a passive setup makes things easier and more difficult at the same time. Team Bass-Hz
ALPINE408 Posted March 22, 2016 Report Posted March 22, 2016 15 Hz to 50 Hz for the bass? Hum... Let your sub play from 80-100 Hz and lower. Why would you use your SSF at 15 Hz ?!!! Human can't hear under 20 Hz usually. Set the SSF a few Herz under the port tuning. Or at 25 Hz if you're running a big (for your sub) sealed box. I can't see your 6.5" speakers plays that low : I would try 80 Hz for the HPF. and a much higher crossover point for the smaller speakers. Good luck. why set it at 15hz? because even if you can not hear it you your body can notice the "Presence" of those frequencies I have tweeters that go to 40,000hz and you can tell the difference from tweeters that roll off at 20,000hz even tho I can not hear above 20k Have you ever had your woofers blown?
