Port compression and optimization
I'm aware they aren't a hard cutoff but it's not like you need to use a 48 dB or 24db slope for the crossover.
Most likely I'll use a 6db or 12db slope for my system but that will be determined when I tune the system.
A little eq'ing helps too as you stated to get the curve you want.
But there's always a cost as you said.
So you're saying that tuning at 20 or 50 doesn't make a difference in output below 80hz?
As already stated, above 80 Hz.
I hear so many times "I need to tune higher so I can get the higher bass".
More than likely the system has a large peak in the output just above tuning so that all that is heard is the peak, which gives the idea that the upper bass is missing. The proof here would be that upper frequencies do not roll off based on tuning frequency.
The correct idea would be to design a system that didn't have such a large peak in the response.
This is what I was getting at, so people could just tune to 20hz it shouldn't have an effect on output at 50hz compared to tuning at 35hz right?
Yeah within reason. If the example you gave 35 Hz is close enough to 50 Hz that you probably are going to see a difference vs a 20 Hz tuning.
Builds:
great read still!!!
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
Is it not true that our ears can begin to localize sounds somewhere around 80hz - 100hz?
If that is true why would you ever want to have your sub covering frequencies up that high?
I cross mine at 63hz typically.
One way to get around this is to use an array of drivers at low frequencies. For instance, if you have four drivers covering the two octaves from 80-320hz, and those four drivers are in front *and* behind you, it's going to be difficult to localize where they're located.
I am using this trick in my current build; I have the subs running all the way to 200hz and I have six midbasses total. The midbasses are under the seats *and* under the dash and they're time aligned. (Don't bother doing this if you can't EQ and time align them; all the midbasses need to arrive simultaneously and have the same response.)
  • 1 month later...
With all of your testing ability, another fun project would be to build a nice flat enclosure (.707 Q) and look at impedance plots.
Then using the impedance plots, compare output at the lowest and highest impedance frequencies.
You could also do this with a driver in free air.
Would be nice to show everyone that just because a driver has an impedance spike at Fs, you may not be providing as much power at that frequency, but that doesn't mean you are getting a big dip in the output.
If you have a Fi driver, a nice free-air impedance plot would be cool too. Just so everyone can see the difference between DCR and impedance.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • 9 months later...
I just read this. Good stuff.
Pioneer 80PRS
  • 1 month later...
Awesome post. Love learning things about box theory.
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
