sub just stopped working... is it blown ?? someone enlighten me.
I was running subs today at about 1/2 volume of max . My system has been tuned with the dd1. No eq or bass boost everything set flat and 0. Today with volume lower then usual... I heard a noise that was a loud buzz sound and then it sounded like a slinky hitting a wall. I immediately pulled over and the sub was still playing just not as loud. I pushed on the front and I can feel the coil rubbing. The sub was not hot or overheating. I had an old JL audio blow before but it usually would be super hot and have dust/smoke coming out the holes. This sub is a newer w3v3 that I have had for less then a year and purchased as a pair. The other is completely fine. When I put the multimeter on it, it read open but when I move it, it jumps around in Ohms alot. Could someone enlighten me or what may of happen? Is it blown or did the suspension go on it?? I plan to get it repaired by JL because they charged a flat rate repair of $150 on w3v3s. Both tinsel leads look perfectly fine and the spyder is untouched. From within the cone I can feel the whole shape of the coil pressing forward.
When subs move the ohm reading will change. Hence the word "nominal" . If you get a reading at all it probably isnt a blown coil. Take it out and look at it
I have taken it out of box already and listed everything that is visible to me in post. I feels as though what holds the coils down by the magnet has broken and is letting the coil move freely up to the cone. I have never had an issue like this before especially so early on. All my JL audios typically last about 5 years before issues. I feel like this sub may have had some type of factory imperfection .
Subs either work or they do not, there is no in between.
When something feels funky then most likely it has an issue and either needs a recone or replacement, just because it is a JL Audio does not mean it can't be fucked, your just assured a certain amount of quality with their products, you'll either need to repair or replace it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
You kicked its butt. Coil rub = toast.
Pioneer 80PRS
Can you see the actual coil through any vents below the spider pack?
Nope completey sealed all the way around. Like I said it looks as those its brand new minus the rubbing. When I push down on spider on left nothing but on right there is rubbing , which is the same rubbing occurring on top by cone. I guess what I was trying to figure out is the damage on it my fault or something malfunctioning?
150$ to repair 225$ woofers? yeesh. Glad theyre getting your business not mine.
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
  • Who's Online   0 Members, 0 Anonymous, 2010 Guests (See full list)
