corrosion on CCA speaker wire !!??
I bought 25ft spool of execution audio 12Ga CCA speaker wire on ebay for $13 and recieved it today. Un winding the spool i noticed after about 4 feet there was a defect in the jacket (for about 1/8 of an inch) and the wire was exposed. I also noticed some very faint white/greenish powder residue in the wire. So i cut it there an inch before and after the defect and inspected it. The wires have a very light powder through out the strands. Is this normal for CCA wire ? I hate wasting money even $13 so if its not safe to use it i wont. I hoping to get some feed back or experience on this... Its not much residue its pretty faint but i dont know if the rest of wire is infected (more or less) unless i OHM out my runs....
Sounds like you bought used wire.
I cant see it being unsafe to use.... sounds like the copper clad started to oxidize hence the green color
I bought some OFC speaker wire back in 1999 and it took 4 years to find out that it was probably not OFC because all the strands turned green right to the core and started losing signal, I had to then take it out and replace it.... all it was going to was my tweeters and I started to hear them cutting out at low volume.... personaly I would avoid using it unless its for something with very easy access / short runs
pretty sure that would mean it was in fact OFC. just not tinned. I am going to switch to tinned OFC anytime i buy wire anymore.
Most metals oxidize, so going to cca won't help you, you have to tin and seal the wire to reduce any chance you'll get oxidation.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
It was a brand new roll all factory packaged on a spool, prolly old sitting in a warehouse. Im gonna set it off to the side, i have a new oppurtunity. Ive ran scocshe 14ga from walmart and never had any quailty problems, figured this wire would be better quailty but no lol.
Its faint white powder (highly doubt the manufacture drop a kilo on the wire before insulation) the actual wiring looks fine. But im gonna set it aside on the shelf because i dont like "what ifs"
Thank you guys for your input i appricate it.
Even OFC will do this. Marine wire is tinned to prevent this. This is also why adhesive lined heat shrink should be used on terminals under hood and under car. Maybe you could contact the seller and let them know that this is unacceptable and give them the opportunity to make it right.
Pioneer 80PRS
i second that contact seller
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
