6th order #s
Just finished a 6th order in my trailblazer and have been tweaking and messing with the rear port now gonna start messing with the front port round overs shrinking etc,and was curious as to what some other 6th orders were putting up #s wise.what kinda results you got with shrinking ports,making ports bigger,round overs etc...I could literally spend hours if not days tweaking
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
A few #s I got with tweaking....all sealed on the dash of course...6in aero port in the rear
Rear port upped to 8in
All scores are at 2ohm on an AA 8.0TFE....Previously did a 151.6@ 35hz then dropped it down to .5 and did this....raised my peak 2hz
Designed and helped build both of these.
This one is 4 Nsv3 15's with v1 Megaroll softparts on 2 Banda 7k's, does a 58.5 @ 39hz and a 156.4ish @ 25hz.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Nice! Mine are temp dual Frankenstein 18s on a TFE....my EMF ermagerds are being built in to 18s as we speak with new sundown baskets and 12in spiders.
Gonna do a bunch of testing at .5 this weekend before messing with the front port
Teammate with 4 custom X3 18's does 57/58 @ 40 or 41 on a 10k, plans to do a second 10k later on.... so hopefully 60's in the low 40s this summer with some tweaking.
  • 2 months later...
Alittle bit more tweaking to the front and rear ports went to an 8in aero in the rear tuned to 25hz(previous port was a 6in aero tuned to 21hz) and dropped the front port down to 169sqin using round overs tuned to 42hz(previous port was 289sq in tuned to 48hz) plays 15hz-50hz with authority which was my goal....with the larger front port it played up to about 65hz before dropping off now drops off around 52hz...might try a slightly larger front part like 225 sq in with round overs....so far I love the way it sounds main goal was to do psyclone
All numbers I posted are Sealed on the dash.......this is on the dash driver window down......subs I'm currently using are some borrowed Custom Franken 18s on a TFE at .5ohm ....18 Solo X motors,Ti baskets,triple 10in spiders,PE 8 layer 3.5in voice coils and Sundown Spl cones....gonna throw in a pair of sundown Zv4s I just got reconed and see how they do before throwing my Custom Ermagerds in
2 12" power acoustiks mofos, series tuned 6th order blow through, initial tests. Truck running, driver door open at the dash. Does hair tricks
Wattage was incorrect on this one but it was around 2000wrms
  • Who's Online   0 Members, 0 Anonymous, 4697 Guests (See full list)
