d-nice88 Posted June 24, 2016 Report Posted June 24, 2016 Im hearing this what sounds like a mechanicle noise cooming from one of my 15's and you can only really hear it on the kick drum bass notes or the higher notes like 50 60hz range. Any one know what this could be ?
Triticum Agricolam Posted June 24, 2016 Report Posted June 24, 2016 Dust cap coming loose? Torn spider? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Kyblack76 Posted June 24, 2016 Report Posted June 24, 2016 Dust cap coming loose? Torn spider? This. Or a bubbled coil, or bent former....... Pull out from enclosure, and free air it at said freqs. Youll find it. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Nightshade Posted June 24, 2016 Report Posted June 24, 2016 Could be coil rub, or possibly the triple joint is starting to fail. I had this happen on a sub in the past and it sounded weird at higher frequencies but did not in the lower frequency range. I pulled the subs and the triple joint was starting to rip, so I grabbed a bit of 5 min epoxy and re-glued that bastard down. It fixed it for quite some time until the portion where I had glued it to the cone started to rip. You can't save a sub forever by half-assing it, but sometimes it will work for a while to get you by. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
deathcards Posted June 24, 2016 Report Posted June 24, 2016 check for leaks in box around sub skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
d-nice88 Posted June 25, 2016 Author Report Posted June 25, 2016 Ok so im bout to remove my sub and now if there is not joint failure or spider tear and no coil run then what else could i be hearing ?
Triticum Agricolam Posted June 25, 2016 Report Posted June 25, 2016 Ok so im bout to remove my sub and now if there is not joint failure or spider tear and no coil run then what else could i be hearing ? Test it first. then worry about what to do if you can't find anything if that situation arises. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
d-nice88 Posted June 25, 2016 Author Report Posted June 25, 2016 Omg.. L O fucking L.. i took both subs out and everything was perfect still stiff and both coils read .7 ohms. (Fi bl 15's) so i hook everything back up and play a track i hear it real good on and still hear it and im like WTF! So i readjust my self to get a better listen and my ear gets close to the cargo lamp in my truck and there it is... fucking sound ive been hearing this whole time omg such a relief / dumbass moment lol.. thanks guys for yalls help tho. Now i just gotta figure a way to stop that damn noise.
Karkov Posted June 25, 2016 Report Posted June 25, 2016 Glad it was something simple. happy ending 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
