Not sure if electrical is good enough
Hey guys new here. I'm in the middle of my build. So far I have mechman 240 am h/o alt. Big 3 upgrade and Xs d3400 under the hood. Im looking to get 2 sundown audio zv4 12s wired to 1 ohm on crescendo bc5500d amp. Plus a 500 watt 4 channel amp for mids. I'm planning on putting 2 additional d3400 in the back. Was gonna go for just one bigger battery in the back but from what I've read people recommend keeping the same sized batteries. My question is is that will this electrical be enough? Btw it's going in 1999 Jeep Cherokee sport. Thanks
You can put d31's in the back instead of the d34's but that's your choice. Everything you say looks good and I assume you will be using 0 gauge wire. The only thing I would note that you might want 2 runs of 0 gauge from the front to back. It will help out and it's not that much of an expense.
BTW I have a mech 240 with a d6500 in front and 2 d31's in the back. No problems.
I'd get 2 2ks and strap them to 1 and get 2 d31's B)
Why strap 2 smaller amps?
I BD linked 2 RF 2k's :) 6 batts and 200amp alt
Hell yeah on the rf amps!
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Okay cool thanks. What do you mean run 2 runs of 0 guage? How do you do that. Sorry suck when it comes to electrical
My suggestion would be to replace the 2 D34s in the back, and replace with 2 D31s.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
