s5300 Posted July 4, 2016 Author Report Posted July 4, 2016 Honestly, as much as I hate to say it the amp will probably work just fine. Thanks yo. Along with Mario.. I appreciate your effort, but please don't just rail shit out. Make a comprehensive post.. To make the whole situation funnier, this is going in a jeep. Completely stock. I can't make everything right man.
s5300 Posted July 4, 2016 Author Report Posted July 4, 2016 Shit. So, he canceled the order of the hifonics.. back to finding something. More suggestions guys.
s5300 Posted July 4, 2016 Author Report Posted July 4, 2016 I plan on telling him to get either https://www.amazon.com/gp/offer-listing/B00EPMNAIS/ref=dp_olp_new?ie=UTF8&condition=new or https://www.amazon.com/Soundstream-PN1-650D-Monoblock-Picasso-Amplifier/dp/B008L117RK What exactly does the single channel mean? He's running two 300W RMS 4ohm SVC subs. Will everything work correctly? I don't want to dick him or anything.
Mariothadon Posted July 4, 2016 Report Posted July 4, 2016 4 ohms can only take 1 ohm... he needs a 1 ohm amplifier and not a 2 ohm!!
Wasteland_Audio Posted July 4, 2016 Report Posted July 4, 2016 4 ohms can only take 1 ohm... he needs a 1 ohm amplifier and not a 2 ohm!! But 2 SINGLE voice coil dubs can be wired to 2 ohms.
notorious97200 Posted July 4, 2016 Report Posted July 4, 2016 4 ohms can only take 1 ohm... he needs a 1 ohm amplifier and not a 2 ohm!! You read too fast : he has 2 Single VC, so he can only wire to 2 or 8 Ohms ! Get the PPI amp, it's cheap and not so bad ! Personally I love JBL, and their 500.1 looks fine ! RF is a good choice too. You have enough amps to chose from. It's up to you. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
s5300 Posted July 5, 2016 Author Report Posted July 5, 2016 Okay, he went ahead with the PPI. This is probably going to be the dumbest question I ask on the forum for a while.. What's the difference from the PPI and the Hifonics where the PPI has one set of RCA input and two speaker inputs while the Hifonics (and most other monoblocks) seem to have two RCA inputs and four speaker inputs? I couldn't find any concrete answer, only something to do with signal strength perhaps? He's going to be able to run dual subs fine on the one pairs, right?
Nightshade Posted July 7, 2016 Report Posted July 7, 2016 Okay, he went ahead with the PPI. This is probably going to be the dumbest question I ask on the forum for a while.. What's the difference from the PPI and the Hifonics where the PPI has one set of RCA input and two speaker inputs while the Hifonics (and most other monoblocks) seem to have two RCA inputs and four speaker inputs? I couldn't find any concrete answer, only something to do with signal strength perhaps? He's going to be able to run dual subs fine on the one pairs, right? Most of the time there aren't two sets of RCA inputs. One is a pass through or even an output. As far as the speaker inputs it makes it easier to just wire straight into the amp if you are running multiple speakers. That way you don't have to wire in series or parallel before the amp, you can just connect speaker wire to the amp and it is a parallel connection internally. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
