Skullz Posted July 8, 2016 Report Share Posted July 8, 2016 Check your connections by pulling on them, and not some pussy ass light tug, pull that fucker. Pull all power and ground connecting points by cleaning and reconnecting them from the alt all the way back to the amps. As was said earlier, pull the speaker wires and rca jacks and try that first to see if things have changed for the better. Finding and correcting problems is a process of elimination, you just have to take your time and work from one end to the other until you find the culprit. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
MrSkippyJ Posted July 9, 2016 Report Share Posted July 9, 2016 Check your connections by pulling on them, and not some pussy ass light tug, pull that fucker. Pull all power and ground connecting points by cleaning and reconnecting them from the alt all the way back to the amps. As was said earlier, pull the speaker wires and rca jacks and try that first to see if things have changed for the better. Finding and correcting problems is a process of elimination, you just have to take your time and work from one end to the other until you find the culprit. That's the mother fucking truth right there! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
CamEnglish Posted July 13, 2016 Author Report Share Posted July 13, 2016 ok so with the truck off and amp off i get 12.xx volts so my power wire and also my battery. With the truck on i get 14.xx volts also to the power wire and the battery and 13.5x volts to my remote wire. as soon as i turn the remote on my power voltage drops to 9.xx volts. Is this normal? 2009 Chevy 2500HD 6" Lift 35" Nittos 22"x13" Fuel Kranks Pioneer App Radio 3 Alpine 500x5 Memphis PRX 1.1000 Memphis Mojo5 12" Red Oracle Halos Link to comment Share on other sites More sharing options...
CamEnglish Posted July 13, 2016 Author Report Share Posted July 13, 2016 Disconnect all speaker wires. Amps go into protect due to low impedance as well. Eliminate one potential issue before focusing in on the other. If you are testing your voltages using the amp's ground as a reference, 11-12V differential from ground terminal to positive should not be putting it in protect. Anything less than 9-10 volts is typically the danger zone. Low voltage on remote and the amp simply shouldn't turn on. I just disconnected all speaker wires but it still is dropping to 9.xx volts when the remote is on. is this normal? 2009 Chevy 2500HD 6" Lift 35" Nittos 22"x13" Fuel Kranks Pioneer App Radio 3 Alpine 500x5 Memphis PRX 1.1000 Memphis Mojo5 12" Red Oracle Halos Link to comment Share on other sites More sharing options...
jk13 Posted July 13, 2016 Report Share Posted July 13, 2016 With the truck on i get 14.xx volts also to the power wire and the battery and 13.5x volts to my remote wire. as soon as i turn the remote on my power voltage drops to 9.xx volts. Is this normal? This makes no sense. With the remote off it (the remote wire) should be 0 volts, not 13.5x. You then 'turn remote on' and something drops to 9.xx--is that the power wire, or the remote? Are you using a head unit to turn the remote on, or a switch? Static drops are my bag. Link to comment Share on other sites More sharing options...
islandpride684 Posted July 13, 2016 Report Share Posted July 13, 2016 Replace your power wire and your fuse holder at the battery connection...or just the fuse holder and if that doesn't fix it replace power wire... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted July 13, 2016 Report Share Posted July 13, 2016 If your power input to your amp drops to 9v when it is turned on then you have a bad connection somewhere on your power / ground wire or your amp has an internal short. What size fuse do you have at the battery? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
deathcards Posted July 13, 2016 Report Share Posted July 13, 2016 after re-reading the first post it sounds like a battery has gone weak but it would help as skullz posted \/ skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
Skullz Posted July 13, 2016 Report Share Posted July 13, 2016 We're getting bad info to try and help you with. What is the voltage with the vehicle on? What is the voltage with the vehicle off? The remote wire simply turns the amp on so the drop you see is from the amp being powered. If the voltage drop is significant than you have an issue with a connection somewhere, and if you went through all your connections as i pointed out in my previous post you would have found your answer. We have done our part, it is up to you to do your part in finding the problem. Once you go through all your connections and the problem still exists then you'll want to try another amp, but you could try that first also. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
