IH8PunkRok Posted July 25, 2016 Report Posted July 25, 2016 I don't really know how many times I have read about 4th orders and seen comments like "I like a 1:1 anything bigger is too peaky" "big ratios are peaky and sound bad" Peaky peaky peaky That's the buzzword with 4ths. Recently I built one. See what Peaky really means 2 18s 3500 watts 6 sealed 20 ported Plots out as so in BBP Peaky By the time I get to 30 hz it'll be 9 db down!?! This will surely sound like shit. But it doesnt. In fact it plays the lows astoundingly well. Why? I don't hear that 47 hz peak either. Strange. Lets investigate 25 burps later I have data I compiled the data into a couple graphs and found a pretty interesting result SPL in Blue Power in red From 27-46 I have a 1.5 db range which I consider pretty flat. Figured I'd share my experience. Maybe push some people who are on the edge to try one. Discuss? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
frogcase2002 Posted July 25, 2016 Report Posted July 25, 2016 Alot has to do with the vehicle also. I also have tried 4th order bandpasses that dont look to good on paper but were pretty decent in the vehicle. Also have had the opposite happen Clarion cz702 Ssa evil mids and tweeters ppi 900.4 2 zcon 18s Taramps 10k 3 big dekas 1 xs 3 runs of 4/0 and big 3 300+ amp ohio generator 155.7 on dash at 36 (peak) 152 at 25
hdorre Posted July 25, 2016 Report Posted July 25, 2016 I was a 3.5:1 4th. It was noticeable how flat it was from ~27 to 55ish (as high as id play). People commented time and time again how flat it was. I wish i hit the TL to record data before I tore it out. Ive got friends with 4th order walls as well. The smallest we try to use is 3:1. On paper, it may look peaky, but the real world is a different animal as you know. Besides, we like output.. right? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
RooTxBeeR Posted July 25, 2016 Report Posted July 25, 2016 Good info right here, subbed to see some argument going on about what is real and what is not. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Joe X Posted July 25, 2016 Report Posted July 25, 2016 The bump at the low end is definitely cabin gain, the modeling software needs more data to display a more realistic plot of the situation (happily unlike WinISD BBP is designed to be able to adapt somewhat), there is also cancellation, losses, etc and the location of the mic to do the readings to explain why you get what you are getting. It would be great if you gave detailed specs of your enclosure and some pics of the install if you want greater insight on your results.
Triticum Agricolam Posted July 25, 2016 Report Posted July 25, 2016 What subs were you using? What vehicle? What were the specs on the port? It's nice to see numbers/graphs to go along with what you are describing. Not many people provide that. In addition the the environmental factors that affect frequency response, the parameters of the sub have a big effect as well. A high Vas, high QTS sub is going to have a LOT broader bandwidth than a low Vas, low QTS sub when put into the same spec box, for example. Over generalized statements ("high aspect ratio boxes are/are not peaky") are universally ill conceived. Every situation is different. Also, bandpass box ratios are dumb. :-) "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ShadeTreeMechanic Posted July 25, 2016 Report Posted July 25, 2016 It seems to me that the low end response is the sealed section. Below port tuning it would not make the second chamber and port resonate. It would just play through the port like it wasn't there. if the port is big enough. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
IH8PunkRok Posted July 28, 2016 Author Report Posted July 28, 2016 Subs are RE MT 18s, vehicle is a 2005 dodge magnum walled almost to the b pillar, about 300 sq inches of port 4.5 inches long, port drivers side, measured at the headrest passenger side Don't have any pics handy atm -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
