The Trouble With 4th Order Bandpasses
I don't really know how many times I have read about 4th orders and seen comments like "I like a 1:1 anything bigger is too peaky" "big ratios are peaky and sound bad"
Peaky peaky peaky
That's the buzzword with 4ths. Recently I built one. See what Peaky really means
2 18s
3500 watts
6 sealed
20 ported
Plots out as so in BBP
Peaky
By the time I get to 30 hz it'll be 9 db down!?! This will surely sound like shit. But it doesnt. In fact it plays the lows astoundingly well. Why? I don't hear that 47 hz peak either. Strange.
Lets investigate
25 burps later I have data
I compiled the data into a couple graphs and found a pretty interesting result
SPL in Blue
Power in red
From 27-46 I have a 1.5 db range which I consider pretty flat.
Figured I'd share my experience. Maybe push some people who are on the edge to try one. Discuss?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Alot has to do with the vehicle also. I also have tried 4th order bandpasses that dont look to good on paper but were pretty decent in the vehicle. Also have had the opposite happen
Clarion cz702
Ssa evil mids and tweeters
ppi 900.4
2 zcon 18s
Taramps 10k
3 big dekas 1 xs
3 runs of 4/0 and big 3
300+ amp ohio generator
155.7 on dash at 36 (peak) 152 at 25
I was a 3.5:1 4th. It was noticeable how flat it was from ~27 to 55ish (as high as id play). People commented time and time again how flat it was. I wish i hit the TL to record data before I tore it out.
Ive got friends with 4th order walls as well. The smallest we try to use is 3:1. On paper, it may look peaky, but the real world is a different animal as you know. Besides, we like output.. right?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Good info right here, subbed to see some argument going on about what is real and what is not.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
The bump at the low end is definitely cabin gain, the modeling software needs more data to display a more realistic plot of the situation (happily unlike WinISD BBP is designed to be able to adapt somewhat), there is also cancellation, losses, etc and the location of the mic to do the readings to explain why you get what you are getting.
It would be great if you gave detailed specs of your enclosure and some pics of the install if you want greater insight on your results.
What subs were you using? What vehicle? What were the specs on the port?
It's nice to see numbers/graphs to go along with what you are describing. Not many people provide that.
In addition the the environmental factors that affect frequency response, the parameters of the sub have a big effect as well. A high Vas, high QTS sub is going to have a LOT broader bandwidth than a low Vas, low QTS sub when put into the same spec box, for example.
Over generalized statements ("high aspect ratio boxes are/are not peaky") are universally ill conceived. Every situation is different.
Also, bandpass box ratios are dumb. :-)
Builds:
It seems to me that the low end response is the sealed section. Below port tuning it would not make the second chamber and port resonate. It would just play through the port like it wasn't there. if the port is big enough.
Pioneer 80PRS
Subs are RE MT 18s, vehicle is a 2005 dodge magnum walled almost to the b pillar, about 300 sq inches of port 4.5 inches long, port drivers side, measured at the headrest passenger side
Don't have any pics handy atm
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
