bman8891 Posted August 9, 2016 Report Posted August 9, 2016 Im building a box for my buddy in his civic. We're facing it forward and sealing it off but if I put the port on the side it is partially blocked by the trunk opening. I can put it in the middle but its easier to build this way and I feel like its more efficient. Only about 25% of the port is blocked what do y'all think? By the way hrs using (2) DD 2512's and hifonics 3200.
Rich Schenk Posted August 9, 2016 Report Posted August 9, 2016 I wouldn't do it would probably change port tuning But I'm no expert On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
ShadeTreeMechanic Posted August 9, 2016 Report Posted August 9, 2016 It would probably only make a small difference. If I did it, it would bug the crap out of me. I would put it in the center or bottom center. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bsneon98 Posted August 9, 2016 Report Posted August 9, 2016 It would probably only make a small difference. If I did it, it would bug the crap out of me. I would put it in the center or bottom center. Exactly what I was going to say. On the box im building now its blocked by sheetmetal 3/4" tall and 3" wide, not enough to make a difference but it already bugs me and I havent even loaded the subs yet. Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
MADVIBES Posted August 9, 2016 Report Posted August 9, 2016 I say it doesnt make an punce of difference the only tuning it would change would be to lower it slightly, no big deal and its far enough away not to cause audible turbulence. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
3vil Posted August 10, 2016 Report Posted August 10, 2016 Why not just redesign your port shape so that this isn't an issue?
Karkov Posted August 10, 2016 Report Posted August 10, 2016 Don't block the port. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
bman8891 Posted August 10, 2016 Author Report Posted August 10, 2016 Thanks guys I moved it to the middle
